Tommy Bahama Battery
Hi all,
I recently got a Tommy Bahama Decade (TB1017) for a battery change.
I had to remove the bezel around the crystal and the crystal ring.
I'm still unable to remove the movement.
The case is one piece with no back.
Tried to find something on line.
Called a company and they said it would have to be sent to Precission Time in Utah.
I'm guessing it has a two part stem, similar to some pocket watches.
Is this correct, and if so, what is the proper way to disassemble the stem and get to the battery?
Thanks in advance,
Dave
Is this correct
It does sound like it will have a split stem in which case a very firm pull will be required to remove it. Occasionally it is possible to turn the stem to a position to allow the movement to fall out.
As Clockboy says pictures may help identify the solution.
Sorry about the delay,
I've had a lot of things going on since my last post.
Geo may have hit on something. I tilted the case and the movement fell out.
I've included picts. I had some trouble directing the focus on certain areas.
When reassembling, I tried to align the keyed stem parts and drop the movement in.
It worked.
Thanks all,
Dave
P.S. Let me know if the quality is OK.
  • 6 years later...
I know this is an ancient post, but my dad just handed me this exact same watch tonight and he wants me to replace the battery.   So to remove the bezel and crystal, did you just use a case knife?  I can feel it has just a bit of a lip when I feel it with my fingernail, but I'm afraid I'll roll that little edge if I start prying at it with a case knife.   I don't see any indentations or anything that shouts "start here" on it.  Also I'm not real clear on how the stem came out in the post above.  Does it not need to come out to get the movement out?   Did it just require tilting the case the right way?  I'd hate to get the crystal off and still not be able to get the movement out.  Any help is appreciated.  It's a nice watch, being silver and all.. I'd really like to get it going for him again.  Thanks.
Check topic below for a discussion on useful opening tools, as an easier and safer alternative to working slowing around with a sharp blade.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
