Lorch Lathe And Collets
Andyclient
Managed to aquire this yesterday a Lorch lathe with 24 collets i assume it is 6mm from the collet shaft measurement or do you go by chuck diameter which is 10mm .
Starting to get the gear but still no idea ;-)
BCC1432F-D208-4E9F-AF62-9DA4F0C08512_zps
Edited by Andyclient
The measurement is the shanks diameter i.e. 6mm or 8mm. I am not aware of a 6.5mm for the Lorch. When purchasing collects be aware not all collets are interchangeable as different makers had different pitched threads for their collets.
Thanks Clockboy it is defo 6mm but i will bear the thread pitch in mind , need to source a drive belt next
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
