I own a Citizen Eco-Drive E168-S070830.  I dropped it several years ago and it quit working.  I finally sent it to Citizen for repair and was given an estimate of ~$453.  They reported the movement needed to be replaced.  This was an extremely expensive quote so, I figured I attempt the repair myself.  I found a couple of places (EBay and a part supply house) that I could get a new movement.  Right after I ordered from Ebay they ran out of stock, then tried the supply house and they would not sell it to me because I don't have a jewelry or watch business.  My search continues so I have a spare.
I did buy some tools and decided to open up the watch and have a look.  I attempted to remove the stem so I could get the movement out after finding some repair instruction for similar movements on Nomad1001's post.  I had some difficulty and while trying to figure out if I had the stem in the right position for removal I turned the watch face up and noticed the second hand moving.  There was no battery in the watch and when I removed it out of light the second hand stopped.  I never got the stem out but something must have slipped back into place. I put the battery back in, put the back on and put it under a lamp.  It's still ticking.
I must be lucky today.  I wish Citizen would have at least attempt to do what I did instead of assuming the movement was bad and needing to be replaced.
I am also more and more of the belief that I should be able to attempt these type of repairs at my own risk and that the parts to do so should be readily available.
Does anyone have a good parts supplier that will sell to DIY'ers?
Parts are oftentimes difficult to get by, and that goes both for DIY'ers and independent watchmakers (the industry generally don't want DIY:ers and independents). Anyway, there are several good parts suppliers, but it very much depends on in which part of the world you live. I live in one of the many EU vassal states (Sweden) so I do most of my shopping on CousinsUK.com. Anyway, start by taking a look at the "Resources" section here on WRT.
https://www.watchfix.com/2019/11/08/watch-parts-tools-suppliers/
Some photos of your watch with the back open would help.
If the hand moves when exposed to light, it might be due to a dead rechargeable battery. You can try replacing the battery and see how that goes.
That is not surprising. The technicians at service centers of Seiko, Citizen and others alike are not trained and instructed to do anything but complete mov.t replacement. Which makes sense, because to the manufacturer that cost little, surely less than qualified labor time. One needs to buy up one segment or two to find "service centers" that actually go in depth on mov.t watch.
Have a read of our pinned topic below
HI   givn the price of the replacement movement it makes more sense to replace it should the need arise.  I have found no data on the E168 but I have attached the E100 tech sheet to give you an idea of its complexity.
E100.pdf
9 hours ago, HectorLooi said:
But unfortunately, Cousins can't ship the rechargeable batteries anymore due to some restriction on shipping lithium batteries ( Really? ).
Yes. Cousins will tell you that this is their post / carrier regulation, no lose Li-ion battery shipments, it's permitted only if contained in the device and up to a certain size. If the UK regulation makes exception for minuscole sizes, I don't know. However, recently they added the option to ship ground to Europe, which helps with these as well cleaning fluids.
All that being said, fortunately there is abundance of other sellers for the same items which are happy to ship anywhere.
Hi Cousins will ship lithium batteries in uk but not sure about other countries but has to be by carrier so charged slightly more as i have just had a couple delivered. also ebay is good source.
in united states jules borel supplies parts not sure about lithium . i even got crown for a citizen that is not available to customers from citizen jules borel ordered from Hong kong and then shipped to U.K took a long time but got parts.
Hope this helps.
Edited by Nomad1001
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
