Possible Restoration
Hello,
I have a Watch in my possession that may possibly be worthy of restoration, but not sure if the movement is of good quality.
I won't be taking on the job myself, as I don't have the required skills yet.
But will be passing it on to someone else, possibly.
The movement in question is an Automatic France Ebauches FE Cal. 5611
Thoughts on this movement welcome.
I've had a few pass thru my hands. Not impressed by the quality and I usually found myself rushing just to get it done and out of my sight.
Having said that, Its your watch and only you know if its really worth it?
Anil
Anil
Can you expand on that at all?
1. Finishing of the plate leaves a lot to be desired.
2. Quality of the screws .. ditto.
3. Hairspring quality does not look as good quality as ETA or other swiss mfg.
4. Ratchet in autowind reversing gear is weak and spares are hard to get.
Basically it feels that it was built down to a cost with quality coming second.
Just my thoughts
Anil
Just my thoughts
Anil
Your thoughts are very welcome.
Food for thought indeed.
May look for a better movement, and keep the original as well.
Any thoughts on an alternative movement.?
Hello,
Why change the movement to another ? I would keep the watch as original as possible . Changing the movement into something else is never an option for me .
Just my thoughts
Anil
It looks like I got this one wrong then! (Where's the embarrassed smiley when you need it)
    • The problem is that this movements were not produced with the modern level of standartization, there for parts from one didn't fit well to another, even if they may look the same. May be it doesn't concern the winding stems, but yet there are not spare parts for such movements in supply companies, not even clear calibre identification possible. And where calibre identification  is possible, there are no Ronda numbers for the balance staff or the winding stem for this calibers in the data bases.
    • That black stuff - I had similar things happen with evaporust!  In that case I understand the evaporust eats the iron oxide away without hurting the metal but it can leave behind a layer of carbon which was in the steel that got oxidised. I spent ages trying to perfect a cleaning regime with various different stages in jars in an ultrasonic bath. In the end I switched to washing all but the balance and pallet fork in IPA and gently brushing it with a small artists brush.  I would estimate that I have found an extra 20º of amplitude doing this! It also takes me no longer than waiting hanging over a tank to move stuff to the next jar If it is really bad then I have used the IPA as a prewash and go through my old routine
    • I thought is FHF. Sounds good to make winding stem by myself but I am not in watchmaking on this level. 😄
    • At a friend's request, I've obtained a key for her long case clock which has been silent for some years. On winding it, the weight only rises a foot or so from the floor - & is not visible above the lower panelled section - before the key meets significant resistance. However it then runs quite happily for a day or so by which time the weight is again on the floor. I haven't had the chance to examine the movement but would be grateful for suggestions as to what might be happening here.
