That's what I believe is part of the issue, can I ask where you get it from , I'm assuming algo will have some ?
Sent from my ONEPLUS A6003 using Tapatalk
I purchased my one from a clock repairer in Staffordshire then I had it fully refurbished by Graham Baxter (http://www.delphelectronics.co.uk). HOWEVER he no longer re-furbs them as there is not enough demand or profit. He still  produces watch timing software. I now use a cheap Indian cleaning machine (JANTA) which is a copy of a Elma which gives me excellent results.
PS is you enter L&R or Varimatic in the search box on this site there is lots to be found on this machine.
JANTA
The link I posted has the fluid listed.
Hydraulic Fluid (Bottle) 11037
Sadly algondo not have :(
I've actually got quite far, have managed to get hydraulics sorted and the synchronisation.
On to the ultrasonics.
Now the ultrasonics light did not come on, the fan kicks in so the switch is working that starts the ultrasonics.
The bulb light up for a few seconds and died.
I have found a replacement and am waiting for it. However the dial control looks to not being doing anything at all.
Does some one have a pic of the underneath with that bit in particular. I want to make sure nothing is missing as I do not see how it would do anything as it looks like a loose switch ( bit at the front)
Thanks in advance
Thanks clockboy , I do have this document , just need some detailed pictures to see if there is a part omissions in the front switch as I don't understand what it actually does!
I was told by the guy who re-furbed my L&R that the original wiring is suspect with NO earth. So he re-wired it, I do not understand electrics so I just took he word for it. What I do know is when it is up and running it is a great machine and cleaning a watch is almost a pleasure.
Quote
Is that big glass bottle a valve rectifier?
It is a single valve  oscillator. I would have suggest high voltage leakage testing and if necessary replacing any capacitors before you even attempt to power it up (but I'm too late I believe).
.. and of course be careful around the ultrasonic circuit, those are pretty high voltages.
The light bulb is quite probably an active part of the circuit.
Edited by AndyHull
3kV capacitors too, so replace with something at least 3kV rated. Check that bulb too, it may be being used as a soft start  current limiter.
Edited by AndyHull
Check the interlock switch too, it may simply be that it needs cleaning and those capacitors are long past their best. The circuit looks pretty simple, so it should be possible to fix it.
4 minutes ago, jnash said:
Yep replaced valve, then capacitor s blew
The dodgy capacitors are the reason the original valve blew.
When fixing old valve gear, always start with a test and replace of capacitors.
Resistors rarely go badly out of spec, and when they do, they generally increase in value, but capacitors are far more likely to be leaky, or wildly out of spec. and that introduces DC in places where only AC should go.
OK Did you bin the whole ultrasonic unit? I suspect any replacement, if of similar vintage, may suffer from the same trouble, so fixing the original may be a simpler, safer bet. The transducer is probably darned near bomb proof, but the capacitors are pretty fragile.
1 hour ago, rodabod said:
1450V on the secondary..... F* that!
I wouldn't recommend that, nor indeed licking it. However since you don't actually need to touch it when it is switched on, you should remain completely unf*d.
Observe some simple precautions and you should be perfectly safe. Its a bit like crossing the road. You shouldn't do that with your eyes shut, and neither should you work on high voltage with the power on.
Keep your left hand in your pocket if you decide to prod things with anything remotely conductive, that way if you do get a tingle, it doesn't go through anything vital (like your heart).
The circuit is relatively safe in the sense that you can see all the bits that will bite you. Its not like working on large switch mode power supplies, X-ray equipment or colour CRTs, which can be pretty angry, even several hours after being switched off.
You might like this Youtube channel. He is old school like me, and works on tube equipment and CRTs. He is a little more blase about touching stuff that I would be paranoid about. He does work with an isolation transformer however, which I would recommend if you are planning on doing much work with anything over about 50V.
BTW Colour TVs work on up to 30kV plus. Even monochrome CRTs use several kV
X-ray tubes go even higher. The xenon flash tube in a small compact camera can blat you with a couple of kV if you are not careful. Don't ask me why I know.
Edited by AndyHull
I have been following this post with interest as I have a varimatic which at present is in garage waiting a fix. The guy who originally re-furbished the machine said the original wiring was poor and dangerous. When I purchased the machine it worked for a while then it caught alight and blew the house fuse.  If I remember correctly the original wiring circuit was was not earthed.
    • Hello Gentleman, Anyone ever work on this watch before? I've been enjoying this hobby for a while now and have had some decent results.  Am progressing nicely to more and more complicated movements,  but man, for the life of me, I can not figure out how to remove this ETA 7750 from the ring around it.  I've successfully removed the movement and its holder from its outer carbon fiber case, but cannot remove it further. I've removed both pushers and the stem and it, frustratingly,  doesn't simply drop out when inverted.  It also doesn't rotate from side to side within the outer movement holder.. it is stuck fast.   I'm a little embarrassed honestly.   The red arrow points to a line in the movement holder, but it is seemingly one piece and not separable there. I guess they just needed to reduce some outer diameter there. The ends of the minute and chronograph hand extend over the minute marking ring so would that mean that that minute marking ring is part of the dial attached to the movement? I guess I'm asking where does the dial end? Any point in the right direction would be most welcome. I've never worked on this movement before and I am chomping at the bit to do so.  It represents the next challenge in my progression. But obviously cant start until I remove it safely and I'm stumped!
    • Donor movement received. Now waiting for a proper & calm time slot to perform the transplant.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
