JLC electric mystery clock leaking volts...
nickelsilver
I got asked by a watchmaker friend to have a look at this, he knows zero about electrical stuff and I know a little bit more than that, haha. It runs on a synchronous motor, which had a broken lead. Another friend soldered on new leads for him, but it didn't run; I got it apart and checked everything, back together, and it runs!
But, if I check with a voltmeter between one of the leads and the chassis I get around 60 volts, and around 7 on the other lead. Also chassis to ground on the variac (to feed it 120 volts), around 60 volts there too. Checking continuity between the leads and chassis (unplugged) I get nothing, checking the coil out of the piece, nothing from lead to coil case, there should not be any way for these volts to be escaping. Any of you electric gurus have an idea what's happening? I haven't licked my finger and touched the chassis and a water pipe yet but I'm getting tempted...
Edited by nickelsilver
The clock isn't earthed is it? It's just the two wires going to the stator. Your high impedance meter might just be picking up mains hum. I'm assuming you're on the ac setting on the meter. Connect one end of your meter to earth and the other touching your finger and you'll get a reading even though there's no real voltage.
I assume when you're looking for coil continuity you have the resistance range relatively low? Like if you're using a digital meter on the 2K range and the resistance here is really high you're not going to see it. So put the meter on the highest resistance range and see if it detects anything.
It's an autoranging meter, so nothing I can change there (there's a Simpson 260 around here somewhere but I trust the digital a little more).
No earth, just the two leads.
Didn't mention it in the first post, but when I started looking it over I hooked it to the variac, on zero volts, then cranked up to 120- with a hand on the chassis- and got whacked! Checking continuity just after and there was definitely a small short from a lead to chassis. I put new heat shrink and potted the small section of wire still exposed right at the coil with some epoxy; after that it's all clean, zero continuity. But I'm a little gun-shy to touch it plugged in now!
OH NO!  Thou doth besmirch the mighty Simpson 260??  In this case the Simpson which (as I recall) 10k ohms/volt will give a much lower impedance to the leads when measuring a voltage and you will likely not experience what @Platodescribed (essentially you are measuring electrostatic potential).  Also use the Simpson to measure the resistance from each lead to case so you dont have to deal with the autoranging meter bouncing about.  I trust the digital meter...dont get me wrong.
Edited by LittleWatchShop
Sounds like you found and fixed the original fault. I don't think we've been allowed to use variacs where I work for donkeys years - no isolation, they're regarded as dangerous!
My guess is that you're just picking up noise on your meter. It's picking up induced voltage like a radio antenna... someone will explain it better than me.
Hmm, OK, I'll get out the Simpson and check again. I guess I'll touch it too? It's only 60 volts...
Edit- Simpson is at home, I'm at the shop, touched the frame and ground with one hand and nada, not a whiff of anything shocking. Thanks guys!
When I was in high school, I began my pursuit of electronics training.  As a sophomore I took a Basic Electronics class and later took two years of vocational radio and TV repair.  On day in the basics class, the teacher was out having a smoke and we had a contest:  who could hold the two leads of a suicide chord plugged into a variac for the highest voltage.  One kid would grab the leads and another would crank the knob.  This was absolutely stupid.  I am sure we all look back at our teen years and wonder how we survived.
  • Haha 2
Maybe you can enhance the effect by standing on concrete that's wet with bare feet.
Although I would really prefer you not try the experiment I suspect you might just get one chance to do it and then you leave the group permanently definitely not desirable.
Any idea when the clock was made? Depending upon the age and quality a lot of the wire really isn't the most desirable and the insulation may not be the best.  Also where the wires come out they may be rubbing on things. C can end up with a very high resistance connection to the frame.
I messed around with some tube gear a few years back, got a good 300v once! Luckily just about 1 second and not across the heart!
I'm pretty sure this is from the 60s. There's very very little info on them. I know some of the really old clocks that run on motors are quite sketchy with degraded insulation on the coils; there are some sites that explain how to wind new low voltage coils with modern wire, then you run off a transformer.
On this one I added extra insulation around the wire that has the heat shrink on it, where it contacts the coil case and movement- you can see that it gets pinched when it's all mounted.
When dealing with leaks, what matter more than voltage is current. Try measuring it if you are curious. For example, one likely won't feel 10 mA, but 30. yes. BTW, your DMM may have a button for manual range selection. Although you would have noticed if that was the case.
Correct. Strange things may happen with cheap DMMs as in seeing voltage decrease, while another meter could reveal the true rms voltage.
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
