Pendulum
Willow
Got this French clock the other day not ready to work on it yet, need a pendulum for it also double ended key problem is i don't no the length of the leader or the weight of the bob.  Are the numbers at the bottom right the length of the leader, hope you can understand all that, can anybody advise me please.
I don't know about the numbers, but you can calculate the length with this calculator
https://theindex.nawcc.org/CalcPendulumLength.php
Weight is far less of an issue than length (effective length is what gives its frequency); what you'll find that's in the ballpark for length will almost certainly be OK for weight.
Yes you can get keys. This is the type key you need. The suspension springs also come in different sizes. If you have the old one measure the length.   Could you post a photo of where the s/s is fitted then I can be more precise on which one to buy. Any good suppler with stock both of what you need.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
