How do I open this
Welcome to the forum, enjoy. The issue is watches that are sold as waterproof are only valid if serviced and fitted with new gaskets fitted particularly those that are around the stems.A picture of the watch would be helpful for a better analysis..
I have a barometer on my work bench that needs a replacement glass.. Diameter 77mm, 2mm thickness. BUT a hole in dead centre. I can source a glass but drilling a hole dead centre without a mishap is high risk. Anyone encountered this dilemma or know where to purchase please give a heads up.
I've inherited a pendulum clock with a broken pallet (please see photo) & I'd be grateful for advice as to whether, & if so, how a repair could be effected. As adhesive - even if it were strong/durable enough - would slightly alter the pallet geometry, I was wondering if a suitably shaped brace could be spot welded to each side edge to effect a connection but could the pallet be cast iron & therefore likely to fracture?. Also, what terms should I use (e.g. descriptive of the type of pallet) in searching for a replacement online?
That’s a great video - thanks for posting it. Sometimes to look forward too when I start looking at the ladies watch movements I guess. Although it’ll be a while before I get my hands on anything high-end I suspect.
Just arrived today with the case a little worse for wear so will probably just polish it back to the steel
