Hello,
I have a question regarding the hair spring.  I have a vintage Durowe movement I am getting running again.  The only thing it needed replacing was a hairspring.  I found a NOS hairspring and balance wheel in France thru Ebay and ordered the part.  When the part arrived I laid it across the balance cock I noticed that the bend in the outer coil was at the stud and with the spring over the regulator pin the outer coil is still concentric.
Now I know that the outer coil leading to the stud needs to be concentric with the rest of the coils but all the movements I've worked on, which isn't many, all had the bend and stud carrier on either side of the regulator pin.  The way this spring is set up, the stud carrier and regulator are on either side of the bend and Im wondering if this is acceptable practice?
Thanks,
George
I am not sure but I think I understand what you are describing.
The bend can be either at beginging or the end of terminal curve or two bends one at the begining the other at the end of terminal curve.
         What matters is the coil is to breath evenly.
Hope I guessed right and this helps.
Older movements offen had the terminal curve almost imperceptibly developed from the outermost coil, with a pronounced kink just before the stud. What you are describing sounds OK, but as others have pointed out, a picture would be very useful.
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
