Repivoting a balance staff
when I was a student in school the instructor I had told of a watchmaker that he knew that was capable of re-pivoting faster the most watchmakers could replace the balance staff. But it would help if you have the right equipment and of course you have the skill set.
For balance staffs, with the exception of marine chronometers, I can definitely make a new one faster than repivoting. Same for chrono runners and minute counters (plus on those it's usually the hand-end pivot and it's iffy friction fitting a pivot where a hand will get pulled off one day). Pinions are another thing. To make a really high class pinion is a huge task, so repivoting is a real solution. A year or so ago I had to do a 0.08 escape wheel pivot on an old LeCoultre, oof, was definitely clinching when: chucking up, catching center, drilling, pressing in new pivot, turning it close to size and jacot tool. An hour job can turn into a full day job fast!
I am impressed with the vid though! He made a neat tool to guide the driiling, and looks like he managed to get the staff running really true, in a larger lathe for this type of work- plus it's Chinese. And used guitar string as pivot material, haha,  not what I would do but probably fine for the quality of the watch (balance looked kinda low-end).
