Can you help please?
UKJohn
Hi all,
I’ve just joined the forum, my name is John and I’m from the UK but I reside in Dubai.
I can see from the forums, everyone seems very helpful, so I’m hoping someone can assist me with a new project I have.
I’ve spent many years repairing and servicing my own collection of watches (pocket & wrist) These are mainly Swiss or UK in original origin, however, a friend of mine recently asked me to look at a watch that belongs to his family and see if I can help him to get it working. It’s an Elgin, it’s a beautiful pocket watch but I don’t have much experience of them. It’s a calibre 451 in a gold case dating back to 1921. At first inspection, it looks like it needs a clean and someone has previously removed the balance bridge and not reinstalled it properly (impulse jewel isn’t aligned I think) but before I can fully ascertain what’s wrong, I need to remove the mechanism. This is where my problems begin. It’s a hinged back lid. I’ve inspected it under a microscope and I can’t see any marks to the case showing how the front should be removed. I’m not sure if it’s a screw fit or friction fit and I don’t want to assume anything as it belongs to a good friend.
Can anyone help please. I’ve attached a couple of pictures for reference.
Hello and welcome to the forum,  The likelyhood of it being screwed from that era is questionable but not impossible. can you post some pictures of the side view of the watch for reference, also if you can open the back there should be a number, if so have a look on the pocketwatchdatabase. you may gather a bit more information.
Could you please post a picture of the inside of the back cover; I would like to know if it is a case made by Crescent.  I have encountered a couple 1920-era cases that were hinge-back & screw-bezel, and I believe they were made by Crescent.
Addendum: if you have not found a lip or a depression by the bexel to indicate that it would snap on or off, then I would first try to unscrew it by hand.  That is the safest thing to try.
Edited by KarlvonKoln
Thank you all for the responses. What mad me question if it was a screw fit was the absence of almost any case markings from previous attempts to open it.
I’ve attached a couple more pictures for the case, just in case this helps a little.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
