Hello From Wyoming
Need to see the pivots on the balance but my first guess would be one of the pivots.
By TimepieceTinkerer · Posted
You're absolutely right — this should’ve been caught earlier if I had tested the train wheels more carefully before fitting the fork and balance. On initial inspection, nothing stood out, but it seems the centre tube shifted when the train bridge was screwed down, which made it harder to spot until later. Anyway, now that’s sorted, I’ve run into another issue: The movement ticks fine in the vertical position (see photo 1), but it stops in the horizontal position (see photo 2). Could anyone point me in the right direction on where exactly I should be checking? I’m also attaching a photo of the balance assembly in case something looks off or unhealthy — please let me know if you notice anything wrong Thanks in advance -
I use the Relife copy of the Amscope and can highly recomend it. Paul
Would be worth starting here Del, if they don’t have it they might know someone https://www.barometerworld.co.uk Tom
What size hands do you need as most wholesalers have a selection. Agian most wholesalers have a selection of crystals depending on the shape. No would be the answer to UV glue as it doesn't work in a sandwich and only the overspill exposed to UV sets.
