2 hours ago, RogerH said:
Check the file size. also the type
Just to be clear, what the topic I have linked before is about is to inform that the only attachments supported are images (JPG and PNG are the formats normally used), and documents in PDF.  Nothing else will work.
9 minutes ago, RogerH said:
it says it at the bottom of the reply window -
Accepted file types: gif, jpeg, jpe, jpg, png, webp
are these only for picture's, or can you use them for video's sorry about this new to all this file lark
Again: no video of any format can be attached. If you absolutely need to share a video, post on YT or other platform, then post the link.
After all that i hope it's helpful thanks everyone for being patient especial jdm who i think might have been calling me under his breath.
I don't think photo's would help i think you need to see the leaver dropping into the count wheel and skips from 9 to 9-30 then drops in, also the stop pin will send photo's gladly if you think it would help .
So it goes from 8-30 and then to nine goes to drop in the slot does a little skip and stops at 9-30, hope you can understand all that and hope the photo's help.
Hmmm there's nothing glaringly obvious.....def need a video lol. how about a gif? it may be enough to show us what happens. If levers are jumping then it's worth checking teeth to make sure there's no damaged, bent or even dirt in between them that may be upsetting the movement.
what i can't understand the rest of the hours and half hours are fine will have a look at the wheels again thanks,
Hi thanks for the pics, As roger said nothing obvious, the lever is dropped cleanly in the count wheel.  Normally when they skip somthing is blocking the lever and it fails to lock properly allowing it to skip. But as yours only exibits the problem at 9  to 9.30 is a bit odd. Are all the other lockings clean and correct.  I should look for either somthing blocking the long  lever or kicking it up so a to release the count, check its operation for the full length and the interposing levers etc.
Yes all the other lockings are ok  thanks
This lever is not parallel to the wheel, so it stops the pin on the wheel at an angel so it could cause it to jump which can cause the strike to act up. Way to much solder on the hammer causing to much weight. A very bad soldering job.
