Filing rest
LittleWatchShop
I have had an obsession for finding a filing rest.  Bid on one recently that went over $350.  Had no clue it would go that high.  I did not get it.
So after looking at what others had done, I decided to try a DIY.  Here is Rev A.  The larger round element is threaded so I can adjust height.
Miles to go before I sleep.
2 hours ago, jdm said:
Very good. Have you seen the one by Dean Williams
http://www.deansphotographica.com/machining/projects/filingrest/filingrest.html
His entire project collection has inspired me a lot.
Yes, I had seen that. His solution is better than mine. If I had the mill he has, I would do something similar.
Before getting a bigger combo machine, I got a TAIG milling column and basic vice from Nick Carter, and used a bit on my Unimat 3 lathe copy. Works OK for light and small size work.
4 hours ago, oldhippy said:
It's a very handy tool to have. Using with an indexing plate shell we say for making a square on an arbor it comes in handy.
Yup...that is why I built this...so that I can make stems.  As is standard for WW lathes, mine has an indexing headstock.
I may need to do a Rev. B of this thing to expand the distance between rollers so that I can get the filing closer to the collet.  I won't know until I do some tests.
  • 5 months later...
    • If you tend to be a little heavy handed then heres something that might help you to prevent cap jewel loses if you have some spare tweezers. File a round into each of the tips so you can grip a capstone or chaton while oiling or moving them around. Instead of filing along the length, angle file the tips first then file the rounds perpendicular to the angle. This way the tweezers wont get in the way of the oiler. Choose an angle that suits your natural hand grip position. The tweezers can now grip round parts on four sides Instead of two that often flip that part away.
    • I had noticed that video before.  He has a separate video for the reassembly. When he started the reassembly with using peg wood to oil a jewel I have to admit that I didn't watch much further. He also advocated not lubricating the center wheel arbor because the cannon pinion is friction fit. There is also a blog post (Adventures in Watchmaking, I think) that has a bit of info but not much at all with the oiling.
    • In view of the modern lubricants available, would you lubricate a clock movement differently today?
    • Yep thats the way it goes. The trick is to lead it into a false sense of security. Go through all the motions of ordering another one but dont actually click that final buy it now button, then stand up say " oh well at least I have another one on the way" .  It will pop its head out and shout " SUCKER ! " . They've done studies you know 60% of the time it works everytime.
    • Hi. I used to live in Tadcaster nor York , there for 40 yrs  moved Aberdeenshire as the place was falling apart.  If you need anything just ask the members on here are very good and patient.
