Hi all.
I have bought a number of the Seiko 7009 to help teach myself watch Repairs, a few complete watches and a few movements for any spares needed to get the complete watches working.
So far I have successfully repaired 3 of them but can't complete the rebuild because on all the watches the white spacer ring that fits between the movement and dial have all cracked into multiple little bits.
Given that this part is almost unobtainable, especially in number, has anyone found a suitable DIY replacement for the ring.
Or if you know of a supplier with any in stock a heads up would be appreciated.
Thanks.
Paul
Cousins have them. Look for 884.283, that's the Seiko part code.
They also have the 884.006 part for the 7005. Its cheaper, metalic, and might be compatible with a 7009, but I'm not sure about it.
21 hours ago, Paul80 said:
Thank, your are a star
I will order both and report back if the cheaper one is suitable.
Paul
I have the same problem and tried supergluing the part. I look forward to your report
Hi all
Just received the 2 versions from Cousins
Both have the same internal and external circumference measurements.
The plastic one is 1.5mm thick and the metal one is 0.5mm thick.
Not sure is the 1mm difference matters, I suppose it might bring the hands closer to the back of the crystal.
Might also be possible to fit 2 metal ones but then the price would be getting close to the plastic one by then.
I have working on a movement now, if I get it going I will try the metal one and report back.
Paul
  • 5 months later...
On 8/10/2021 at 9:59 AM, Paul80 said:
Hi all
Paul
having the same problem myself.let me know how you went on.B.
  • 2 months later...
Sorry for not updating this.
Basically I found that one metal ring was not enough and two gave fitment issues.
I found a seller that had second hand ones in good condition so I bought a few from him. He had them at 5 for the price of one new one so I grabbed them whilst he had them, just checked and he has no more look, the guy in the Netherlands has them at £2.95 each with is still less than a new one from Cousins.
Are you able to link to the seller? Or if not allowed dm me please.
  • 10 months later...
Other option is that if you have a 3D printer or a friend who has one you can print your own for fractions of a penny, there is a 7009 dial spacer on thingyverse and I have uploaded some movement holders which I reverse engineered for the 7009 also, links below:
Dial ring: https://www.thingiverse.com/thing:5286303
Movement spacer type 1: https://www.thingiverse.com/thing:5866398
Movement spacer type 2: https://www.thingiverse.com/thing:5866388
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
