Hi everyone. I trust you're all doing well. There's this vintage micrometer that popped up locally for sale for around $28.88/£22.81/€26.92. Anyone used this model before? If so, is it missing anything? I feel like its missing the sharp knib for the micrometer to measure? But in context of currency, a local Big Mac from McDonalds is $2.83/£2.23/€2.64 equivalent. I added pictures. Please kindly advise. Would be much appreciated, thank you!
Yep H that is exactly it, to protect the finish of the of the hand while it is face down on a steel block. You could stick a toothpick in a piece of wood instead of the stake block but personally i would still thread a piece of paper over the end . By flat lap i mean the flat diamaond plates , i keep using the names interchangeably but the two are different. I've not had to reduce the height of an hour hand tube before , but I've used similar ideas for doing other things
