seiko V657-8120 parts
Hi and welcome to the forum   The movement you quote is now obsolete and therefore parts will be at a premium.  Cousins uk  quote a complete movement as an alternative   VD57  for £10 50 complete. So It makes sense to replace the complete movement and scrap the oiginal for parts. The movement is most probably made by Hattori/seiko/epson who are all the same company but different divisions.
Hello everyone.
I am new in this forum, have asked ones for parts for my flightmaster, was adviced to look at VD57 instead of repairing my original watch. Have search around and find no V657-8120 watch or parts on ebay. That makes me more upset to fix my own  one. I have spareparts list and wonder where to order parts broken or missed.
Any good ideas?
BR
ottarno
Hi  According to Cousins uk list all versions of the V657 are obsolete so the alterative is the VD57 or trawl Ebay in the hope of a donor watch or locate second user parts from previously mentioned sources plus speedtimerkollection site  in europe.  Jules borel and esslingers
On 7/15/2021 at 11:57 AM, ottarno said:
Can anyone tell me of best repair shop / parts for this watch?
There is no best or secret place for parts, actually there's s no guarantee one can get parts at all. Have a read to our pinned topic below.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
    • I started on pocket watches as they are easier to work on than wristwatches. Many had gold cases, which is why there are so many movements for sale. I was always on the look out for cases, for as Nickelsilver says,  a 16s movement will fit any 16s case* (with tweaks to the stem). I also started hand winding mainsprings, before I had winders. It can be done without damage, but it's quite hard on the fingers.  But you can make homemade winders, see here      * some movements, eg "railroad grade", have a setting lever on the edge of the  dial at about the 1 -2 o'clock, so need a special case.
    • Ok, on your movement plate you can see a star wheel on the right, this is the silencer, if you rotate the hands by hand through each hour you will see that eventually it acts upon the cam which moves the lever and in turn lifts the lifting lever thus stopping the chimes and strike working.  What you need to do is get your clock to 11pm and also turn the star until the cam lifts the lever and stops the action. The star wheel has a small spring that gives it a positive action between each movement, so once at 11pm you can rotate the star wheel around by hand until it stops the action at 11pm. Hope this makes sense to you.
