Balance truing tool improvisation
steve1811uk
Hi, I think that I got this for a good price £20 only. I had to improvise as it has a bit missing. What do you think? Will the paper clip work? I'm planning on sharpening the end of the clip into a more defined point. Any idea why the tool has two sides, is that for different pivot sizes?
The paperclip will work fine, the original part is only used as a visual reference so no real difference. There are many versions of these, usually one side will have female cones with holes going rather deep in the center of the cone, then they are cross drilled. This allows the tool to hold a balance by the conical portion of the pivot, which is strong, and in the event a pivot does break, it can fall out either on its own or be pushed up to the cross drilled part. The other side will often just be simple female cones, but can also be a different size of the cone/drill/cross drill type. Sometimes they are actually male cones. On yours I don't see any cross drilling, but that shouldn't be an issue.
39 minutes ago, jdrichard said:
You need to get out your files and cutters and make one that’s exactly like the original.
You are an electrical engineer, not mechanical...BUT...you ARE an engineer...you think like one regardless of the discipline.  I agree...it would be very gratifying to make the replacement part.  I think that is what I would do (also an EE).
Sometimes it is hard to know what is more gratifying...fixing a watch...or making the thing that helps me fix a watch.
Making tools is a NO FAIL adventure usually.
  • 2 years later...
On 1/29/2024 at 6:04 AM, Razz said:
I think you will want to have more than a paper clip if you actually have to adjust your balance.  I recently acquired this one for about $21.50.20240128_2254322.thumb.jpg.c818b503d53bbb4751ede0def37a1abe.jpg20240128_2255052.thumb.jpg.644b9d795fcc2e4ec076ef63c51cf441.jpg20240128_2259262.thumb.jpg.0c91389948eb43f9effe0b948b954589.jpg
Nice tool. Paper clip sharpened to a point has worked very well thanks on a few occasions.
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
