Got this Balmain Paris watch off eBay for cheap to practice my buffing and polishing. The bracelet is much too big to fit me so I need to remove a few links, but this bracelet is like nothing I’ve seen before.
It has pin holes on one side but nothing on the other. I tried pushing to see if the pins are spring loaded but no luck... I thought it was likely that they were screws but I put a few different flatheads inside and they never caught onto anything. I’ve cleaned the holes out the best I could (the watch was very dirty) but I can’t fully see in there, with my loupe on it just looks flat with no screw pattern. Does anyone know how to remove these links?
Hi looking at the bracelet ,on the non pinside there seems to be blanks or plugs which could be obscuring the pin, I would try a gentle punching of the pins to see if you can remove a pin. the links are solid sided and joined across  the bracelet. I. first thought they might be like Rolex and you need a tool to pull the end cap off, this yet may be the case.
I see the blanks/plugs as well but they seem to still only be on that one side, the other side looks like solid steel. I tried punching already as well but maybe I’ll have to go a little harder.
Do you have an example of the Rolex bracelet and the corresponding tool?
Hi there are two tools , one pulls it apart and the other re fits and closes the links. The cost of the tools is way more than the worth of the watch but from the design you may be able to make something that will work.
Ok so turns out your original post was right and there's just blanks on the other side. I had to put it in a vice and use a hammer and a pin (hitting surprisingly hard) before they came out. Thanks for all your help!
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
