Unusual barrel arbour broken!,
clockboy
Sorted sorry no picture of the pin but when I tapped the arbour to remove the lid of the barrel a tinny pin dislodged which I have found on my worktop. It sits here. With a google search it is suggested that this design was to allow removal of the barrel without splitting the plate. This Kienze movement is very unusual  it has two clicks for one on the mainsprings. See pic.
I worked on a similar Kienzle movement before. In fact, it was my very 1st chime movement.
The arbor has a locking pin as you have discovered. I found it very convenient as it was easier to remove the barrels.
The chime barrel indeed has 2 clicks. Yours might be missing one of the springs as the one I worked on had two springs. Perhaps it's because the chime mainspring is so strong that they felt it needed a failsafe.
Yes the picture was taken after I had removed one of the springs. I just could not release the power and lift both clicks at the same time. I presume the arbour can be tapped out while the barrel is still in the clock, if so this one was very tight indeed.
This clock was worked on by the customers farther who tried to not get it running but failed. So it’s just a sentimental clock repair that he wants to see running. But all sorts of scratches, brushed screws and other damage and of cause copious amounts of WD 40 around the movement. So a big challenge but I promised I,ll give it my best attention.
PS another challenge I have raging tooth ache at present so difficult  to concentrate. 😡
Haha. I could help you with your toothache but I'm on the other side of the Earth.
Call your dentist for an emergency appointment. In the meantime ....
If it is a gum problem, rinse with warm saline 3 to 4 times a day.
If it is a nerve problem, take a mouthful of cold water and hold it for as long as possible.
If it's really bad, take an OTC painkiller as directed.
Thanks I have an appointment this afternoon. I have been rubbing in a sensodyne toothpaste onto the tooth which has eased it a great deal.
31 minutes ago, oldhippy said:
This is a system that is used so you knock the arbor out so to release the barrel complete without taking the movement to pieces. Just don't lose that pin. A double click is a safety thing in case one breaks.
Thanks. I have now cleaned springs etc and now clean the winding part of the arbour now  pulls out without too much effort. As you say the pin is small. Its another part of the none ending horological learning curve.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
