Gold Filled Case Renovation?
zenon
Hi,
I am looking at Russian Poljot De Luxe I intend to restore. The case is gold filled 20 microns and as the pic shows there is damage/wear to it. What is the general rule here? Do we restore/renovate cases like this? If so how is this done? What is done to stop the corrosion?
The eaten out gold and brass:
Also the movement supposed to be #2209 (whatever it means), I've seen pictures of the movement and there is the number engraved above the 23 kamnia and the manufacturer stamp. On the one I have the # and manufacturer stamp is missing. Should this other me?
The markings on the bridges:
with the number ect.
pic of mine:
z
Yes - "Kamniya" is jewels.
As far as the half moon shaped concave hollow in the case rim is concerned, it's not damage - it's actually a pry point to assist in snapping off the case back. It's something you see from time to time on some Russian Poljot and Raketa casings. I've certainly seen this before. If you look closely at the concave hollow, you'll see that it's perfectly formed but with some minor damage where tools have been used. I can't say I've seen the hollow under the stem tube before but, again, it looks to be there for a purpose, rather than damage.
Apart from that, the gold filling looks good to me - there's no brassing and just some minor scratching on the case generally, and it looks to be a good movement. I can tell you that to have it regilded by a decent goldsmith/silversmith or casemaker would cost you (in the UK) about £100+ - not worth it.
Cheers,
Will
Cheers,
Will
I am sorry but the picture was rather poor quality and the lighting bad. See this one with arrows:
The arrows point to the corroded niches. I think at first the gold was 'polished' down but wrist's skin to the bare brass and then sweat corroded holes in the brass. One clearly visible is the dint near the stem hole.
But I think you've answered the question - I will just leave it as it is it is used watch is it not? :) I thought that maybe there is like a general convention in this to go THAT far with renovations.
Thanks Will.
Edited by zenon
Hi Zenon,
No real way out of this one.. I assume the front is OK? In that case I would just use it as it is...not so much a daily wearer but more of an 'evening out' watch. You can replate a watch but the resulting finish is no way comparable to how a 'gold-filled' or 'rolled gold' (same thing) looks almost like the real thing!
As for the movement... it could be a) from a different factory or b)from a different period. The Russian were not too bothered about copyright and they production was based on capacity. In your example with the extra word/numbers.. the figures inside the Pentagram would be for the 1st Moscow Watch factory. The ones from Minsk had a more rounded cartouche. Since there is no cartouche it could be from either factory (or even a totally different one!). This movement was made for around 20 years so anything goes! One thought.. since they used the word 'jewel' instead of the Cyrillic equivalent could it have been an export model?
The example with the russian wording also has bevelled edges on the bridges whereas yours has a stepped edge. The bevelled edge is cosmetically nicer but this should not affect the running of the watch.
The 2209 movement is one of the nicer movements from the former USSR, most of them come in gold filled cases and I believe they were at the top of the food-chain back in the day! It was originally made in the 1st Moscow Watch Factory at Kirova. Production was later transferred to the Minsk, Belarus.
Personally I love this watch, especially how silky smooth it winds!..Only two things bug me, firstly I wish it had a Breguet overcoil..most Russian one have these, even the cheap ones, but I believe it was left out here in the pursuit of slimness. Secondly, on most of the watches I've seen, the second hand is too short! I believe this was due to the low dome crystal originally fitted but it doesn't look 'right'.
Anil
I see what you mean - if it's corrosion, it's the weirdest corrosion I've ever seen. It actually looks as though it's been purposely ground down in some way - though for whatever possible reason I can't comprehend!
The wear on the lugs is also odd - you would expect it to be on the inside, where the strap meets the lugs...
Maybe it was dropped/damaged to the point that it was uncomfortable to wear so was filed/smoothed down to allow it to be worn again.
Interesting subject. I've seen watches that have rusted cases and sometimes I can't even figure how the heck it rusted in such a pattern. I guess it is just how people wear them. Nothing much to do there.
@anil. Good information Anil, thanks for sharing!
Cheers,
Bob
Once you get through the gold the brass/ base metal it gets eaten by sweat quite quickly. I have a few 60's Seiko Sportsmatics in similar condition, you just have to live with it. The deep scars tend to be on the back don't notice while wearing. I normally give the cases a good blast in the ultrasonic with detergent and a polish with a Selvyt gold cloth which tends to polish the base metal and blend it in with the gold.
Close up:
But gets less noticeable as you move out:
Its always a problem with gold plated/ filled watches, that why I prefer stainless steel.
Hi Zenon,
No real way out of this one.. I assume the front is OK? [...]
As for the movement... it could be a) from a different factory or b)from a different period. [...] the figures inside the Pentagram would be for the 1st Moscow Watch factory. The ones from Minsk had a more rounded cartouche. Since there is no cartouche it could be from either factory (or even a totally different one!). This movement was made for around 20 years so anything goes! One thought.. since they used the word 'jewel' instead of the Cyrillic equivalent could it have been an export model?
Anil
My goodness you know your stuff Anil! I appreciate your post very much it clears the doubts I've had. The 'Jewel' instead of Cyrylic seems so obvious but I never look at it (My eye glass was most pro0bably too dusty :-) ). Thank you. The watch will be serviced, I will replace the crystal but it will stay worn. I guess I will treat watches like antique furniture - leave some wear and tear.
:bow:
Z
Edited by zenon
    • No real question here, I managed to clean and reinstall this straight. But I just thought I would share this silly design for a balance cap jewel on an old Junghans pocket watch caliber J32. The screw is in the center, the jewel eccentric; the opposite design from every other cap jewel I have ever seen. But it has no steady pins beneath so tightening the screw means the cap jewel wants to rotate away from the hole jewel. Without an automatic oiler, this took about 6 tries to oil and screw down the cap without spinning it away. A tiny bit of Rodico didn't really help. Happily they don't make them like this anymore.
    • Thanks for your most appreciated assessment with this. I will purchase a new movement.
    • Sorry I am confused by step 4. Which screw? There is the balance cock screw. I don’t think that is what you are talking about. The only other screw I see is on the side of the swan neck regulator. I do t think that is the one you are talking about either Well I managed to make it worse again but I could take pictures.  I had put the balance cock partially in place with one locator pin in. I wanted to remove it and I know I should use my screwdriver in the slot to move it off the pin but I didn’t l pulled wit my tweezers and it stuck then gave suddenly and was thrown a few inches away and of course the hairspring got tangled (a coil was above the cock) and untangling it from the cock deformed it.    I am going to try to put it back in shape and I will likely post more pictures after shortly. I’ll wait for feedback before reattaching it to the cock I am sorry I think I’ll give up. I was trying to remove the tangle. I had previously succeeded but now I just made more of a mess with this new tangle.  Lf you see my spring it is now just a knot.  Let’s keep a positive attitude. The movement was already broken. It was working but couldn’t be used. So what if it can’t run anymore… I went on and reinstalled the mainspring in the barrel by hand and managed to put the arbor back in.  Now I need to close the thing!
    • OK, bad video... Almost all of them are. To attach the spring (stud) to the cock: 1. Put the cock on the table top upside down.  Open the regulator if closed. 2. Put the balance on , align the stud above the hole for it in the stud carrier. 3. Help the stud to get in the hole by gentle pressing. 4. When it is in, grasp the cock with balance with tweezers (from aside, not from above), then get it between fingers, not changing the horizontal position, then tighten slightly the screw. This is the moment to correct the high position of the stud - it's top must be even with the carrier. Now tighten the screw. 5. If the outer coil is out of the regulator, move the regulator to the max to '+' position, then guide the spring to get in the regulator. Now You can return the regulator where it was and close it above the spring
