Diesel Watch DZ4343 randomly stopped inconsistently / intermittently
Hi Team,
Need some help, I have replaced a new battery on the watch.
It works but then randomly it stopped and displayed a wrong time,  then you adjusted again to the right time, after 24 hours, wrong time displayed.
Can you please give me some advise, what to do ? things to try.
Thanks for your help
Hi  Whats the caliber number   just below the word japan VD67    ?   .
I have attached the service document for the VD57.    Did you do the reset shorting the ac point to the +ve side of the battery as per the procedure.  If not read the documents and do so to reset the watch.       cheers
Hattori VD57B pg 1-5 (1).pdf Hattori VD57B pg 6-10 (1).pdf
Hi Jordan   Did you do the reset as per the manual and,  what is the caliber number, was my guess right?.  If it is stopping at random it is possible there is some dirt in the movement dried up lubricant etc, If so the only answer is to dismantle and clean the movement or replace it that is why we need the caliber number. That way we can trace another and get a approximate cost.
Hi Watchweasol,
I did reset the AC, I will see how I go,  I think is still delayed,  I will update you soon.
It seems to stopped at nights.
How do you find the caliber number ? I have attached another photo, is it on the back of the case ? no writing inside the case I checked.
4 hours ago, Jordanwrx said:
I just noticed , after reset, it didn't make a different.
The reset is just to realign the chrono hands, does not fix a faulty quartz module. You can have it replaced or try that yourself with hands removing and refitting tools.
7 hours ago, watchweasol said:
To Find the calibre number remove the back and on the silver movement cover plate there will be a number like VDxx or VDxx or such like.
Visible in the picture,  it's a SII VD57C.
Looks like it's related to the date change.  Maybe someone set the day between 9 PM and 3 AM?  Not supposed to do that, as it damages the date driving wheel and possibly the hour wheel.
Now it's catching at the date change.  If the hour wheel is damaged, it might do the same thing at the same hour on the morning too.
Or, it could just be a weak battery and it isn't able to overcome the date jumper.
That problem doesn't exists in modern watches, but sometimes is still mentioned in the owner manual.
The date wheel is protected from conflict with the quick change by finger being retractable, either as is made of flexible plastic, or with a small spring if a brass wheel. On Seiko, the first system is used, see my video below.
https://youtu.be/9EuHG1bYPKs
59 minutes ago, xyzzy said:
That small plastic finger fatigues, then bends too far out, then gets wedged when it tries to turn the date wheel.  This then locks the hour wheel and damages the hour wheel teeth at the point they are driven.
That has never happened to me during the repeated testing I have done of this useful function, and it has been never reported, at least on this forum. Of course, you're welcome to have a different opinion on the matter.
Seiko date driving wheels with bent fingers:
Close up of one of the fingers:
Where the hour wheels get damaged when the date driver jams them and the minute wheel continues to turn:
Is this happening due to the date ring pushing the finger and bending it?  I suppose I don't know for sure.  But the manual says not the do that, it clearly causes the little plastic finger to get moved when it's done, and then we have these date drivers with damaged fingers.  Maybe it's something else that causes it?  But my suspension is the data setting.
Are these from a quartz module similar to OP's one?
My assertion comes from observation and testing of the day/date driving wheel used on the 7S/4R/6R family (sorry for the mediocre pic).
First, it's made of somewhat flexible plastic, the kind that one can deform a little and will return to the original shape.
Then, the fingers are designed not only to push the teeth of the calendar ring or disc, but also to be pushed back from the same without breaking. Their tips are shaped so to recess inward and make the point where it attaches to the body, which is thinner, to flex exactly there.
A clever well executed and proven design that surely saved trouble to many owners.
They are from various quartz Seiko 7Txx movements.  I've not disassembled a VD57 but it's likely similar.
Certainly I've observed the action of setting the date when the finger is in the way, and it's pushed down and doesn't appear to break.  I suspect the plastic fatigues from age and repeated stress eventually.  Or maybe if one does it at just the wrong position, and the plastic is not as slick as it should be, the tip of a date ring tooth will jam against the tip of the date driver finger.
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
