Fusee
Willow
5 hours ago, Willow said:
should i remove these two parts on the fusee for cleaning or leave them on
Pull it apart, this is what will be on the inside.
fusee4.png.5315f5608421ed031b34cb72202a4962.pngfusee3.png.572e0758353a8e276ff3c1a147decbae.pngfusee2.png.0ff3f7591a9cc5adc38dc2fc12c58256.pngfusee1.png.66efbd4f6013ae99705c4cbe014befac.png
Here was the crack on the barrel on my Tameside.
I actually still haven't finished fixing mine, other projects and life has got in the way.
I started to make a new barrel, but haven't finished it.
You can read what I did here.
https://www.watchrepairtalk.com/topic/10659-tame-side-fusee-clock-in-need-of-tlc/?tab=comments#comment-96373
I also made myself a tool so I could measure the inside distance of the old barrel to work out the size I needed to make the new barrel.
I could of gotten away without making it, but it was another easy project for a weekend.
https://www.watchrepairtalk.com/topic/11262-barrel-id-measuring-tool/?tab=comments#comment-101645
just read what you did Tmuir i don't know what i would have done if i had the problems you did don't have anything like the equipment you have (hope i am not talking to soon ) probably take it to a clock repairer or put it back on ebay for spares? nice work you done there
I am putting an order in for some clock stuff i need ,and thought i would order line for the fusee and wondering what if anyone have any views on what type bronze cable or gut ,also some grease for the ratchet is Novostar Barrel Grease good and should i put that on the mainspring too
Stay away from grease for the mainspring use Windles clock oil I've had Fusee's that have been absolutely packed with grease it usually ends up sticking the coils of the spring together, which results in uneven power delivery, clean it with a cloth soaked in lighter fluid or solvent I then put it back in the barrel and put some drops of Windles around the coils it is enough to migrate across the spring never had a sticking spring using this.
Yes a small amount of grease on a couple of teeth of the ratchet it will spread as you wind and a smear of grease where the ratchet spring touches the click and a tiny dab on the post the click goes onto.
Decided to take the mainspring out of the barrel today to clean and inspect it, i noticed a crack in the end that attaches to the barrel when it came to releasing the spring, the end came off and went inside? i then went against everything you are told not to do and ended up taking it out by hand?taxi on hand to take me A&E but didn't need it it came out fine must say my heart was in overdrive.
1 hour ago, oldhippy said:
You will need to replace that spring with a new one. That is what can happen when you remove a spring by hand it doesn't rest flat.
Yes have been looking at companies  they seem to want different measurements counsins want the dia  as well as  the length,thickness and width the dia is that the dia of the barrel
Back again While i am waiting for mainspring to be delivered decided to have a look at the case and dial ,don't know if anyone can advise me on this as it's not related to the movement of the clock ,at the front of the clock is a crack which someone has tried to fill my problem do i take of the mouldings off and see if i clamp and try a close the gap then fill or will that cause it to split somewhere else or just fill it as it is. Next the dial i would like to freshen the face up and the numerals seem to have been painted i not sure if someone has had a go at painting them or if that is how it was. Thanks
The dial would be silvered when new. Have the numerals been painted on or are they filled with wax and someone has touched them up with black paint. The case can be filled by doing this  use a shellac stick. Heat and drip into the crack. Then polish.
The dials are printed  on these not engraved this was to keep costs down in production, if you try to resilver you will lose the numerals and have to paint them back on or have the dial refinished, probably better leaving as is.
Bet you are glad you didn't bid for this now wls1971 new nylon and mainspring £42.14? what is the best way to clean the dial or are you saying leave it as it is
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
