Wave Ceptor--recalled to life
ok, have you try a watch that twist the bezel to open it? and use what tool? I try to pry the bezel and it does not work.
This is the link I use to Ranfft : https://web.archive.org/web/20230305223408/http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk The search function doesn't work, so the link should show all the movements.
By Hawaiikook808 · Posted
