Hi
I have bought 2 pair of levers supposed to be for removing watch hands. But i have had to use them to try and remove hairspring collets also with a mix of success.
They tend to be to thick to go under the collet enough to be able to twist to remove the collet.
I know bergeon and horotc do them but thats for sets which my pocket will not stretch to.
Can any one suggest a decent tool or levers that will actually do this task.
cheers
gary
  I use a safety razor blade, the thin edge slides under the collet with relative ease , open a gap, work your way around the collet to widen the gap, once wide enough you can insert in a scredriver blade, keep on until the spring come off.
You're not supposed to use the levers the way you describe?
You're supposed to kind of combined the techniques of Nucejoe With his razor blade edge and the benefit of the wage shape of the lever.
I have a picture out of the catalog not quite right but close enough. You're supposed to push the levers straight in the sharp edge is supposed to go under the collet.  Because there's a little more of a wage shape than the razor blade edge the collet will lift up naturally. Only when the levers all the way under you could push down and just pop the collet up. Usually that isn't necessary. You never want to twist especially if you're trying to twist to go under the collet because that means you're not under the collet you're on the edge and you're going to lift they hairspring up instead of the collet. In other words a recipe for disaster.
The unfortunate problem of tools not just expensive Swiss tools now that are made cheaply is that they do have to be shaped correctly. I've seen some of the levers that are basically worthless because the shape is not correct.
Razor blade, kitchen knife, levers,  ?️, ⚔️, ✂️ sounds very dangerous, but whatever makes you happy.
I find that many balance wheels / collets are so tiny, that I can only use one or two 0.5mm flat screwdrivers to lift or "unlock" & lift those collets.
You can get the cheap China made hand levers then slowly thin down the edge to a knife edge with a smooth oil stone. That is what I'm using at the moment.
Another technique used is to insert a large oiler into the collet slot and twist it and screw it off the balance staff.
  • 11 months later...
9 hours ago, mooredan said:
Does anyone know which size would be best for old pocket watches?
Probably the 2.5 but that's just a guess. I have levers there at work I'm at home so just guessing and levers I have I almost never use for hairsprings I'm more likely to use them for hands.
Even though you're looking at a catalog the company that's well respected had been in the industry forever doesn't necessarily mean that all the tools are perfect out-of-the-box they might require may be perhaps modification. Then it be really nice if you go to the showroom and look at the tools and see what you really want. Then yes they really do have a showroom I've been there before very long time ago. So it's sometimes hard to tell in the catalog whether this is really what you want need or whatever
Then your PDF has two pages on the second page we find  30018-1 I'm thinking this more closely resembles what I have. Because whatever you have has to slide under the collet before you can even think about lifting up otherwise You will destroy the hairspring.
Then this is the method that I use just not the same tool. Some watchmakers will use their smallest screwdriver that's a mistake. Because the screwdriver has a taper they have a habit of shoving it in and that spreads the collet that's an issue worst-case it breaks the collet. They used to make a tool exactly for this it's basically like the screwdriver tip except it's a very very long taper it just needs to go into the slot. So large and oil are providing it's really flat will work just fine. You should really practice before you start working on a good watch to see how this works but it works really nicely.
Thanks for the advice. Yes, I have purchased several of the same make, model, size, grade from ebay listed for parts or repair before tackling a movement that's in much better shape.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
