Automatic clicking
chrisdt
My Garrard Automatic has developed a loud click at almost every turn of the crown when hand winding. It appears to collect power ok though and also auto winds correctly and keeps working whilst wearing. I have taken the rotor off but have not been able to locate the source of the problem. Any assistance as to where I might start looking would be appreciated
I'd be tempted to take the winder module off too, to see the click, rachet and winding wheel. You not only  have eliminate the parts you removed but might even see the fault starring at you, also wind through rachet wheel, that eliminates quite a bit for the least.
Its a process of elmination, next I guess is checking under dial.
Good luck
Does your watch have a caliber number? Then it almost looks like is a number under the balance rim that would be helpful if there's a number there? We might bill a find a tech sheet perhaps.
Then we can guess because we can't see the automatic mechanism so that probably has to come off. It may be that the reverser wheels have gotten sticky with time but that's just a wild guess. Also the other problem with automatic watches is often times they did not use jewels in critical locations and the holes where out to get oval. So basically this is exactly as mentioned above problem solving and you're going to have to take the automatic mechanism off. Then carefully look at all the wheels all of everything and you should build figured out hopefully
It's always amazing what you can find online if we take the movement number and the name they come up with the links below both of which suggests that the movement is based on  ETA 2783. From that we can a parts list.
https://antiques-atlas.com/antique/gents_unusual_1970s_silver_wrist_watch_garrard/as170a7214
https://www.birthyearwatches.com/product/1974-garrard-9k-gold-automatic/
496_ETA2750,1,2,6,4 ETA 2783.pdf
Thanks JohnR725 for that connection... I must say the gold Garrard which is the same as mine seems rather expensive at £449. I sold 2 of mine last year at less than half that price. But I suppose that is why they stay on sale for month after month after month
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
