minute hand
gary17
hey
Any one know were i can get a minute hand hole size 0.80 cousins only seem to do the hour hands at that hole dimension. Or a way of stretching a 0.70 hole into a 0.80 hole.
Tried drill and also don@t mention heating it up been there done that. Also tried a tapering bit of steel.
cheers
gary
3 hours ago, watchweasol said:
Hi Gary what you need is a hand broaching tool and a set of broaches (reamers) to open the hole out but be very careful not to over do it, check after every twist of the broach and do not use too much pressure whilst cutting  you can not put it back.
Bam!!! Another mystery solved.  I was looking at that tool in my dads watch bench yesterday and wondering what it was for.  In the same drawer is a container of broaches.  Voila!!
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
