Is something missing here?
Mudos
Firstly, make sure you have the correct size battery. Next, of you look at this battery holder, there is a fixed side and a sprung side. You have to tilt the battery at an angle and get it in under the lip of the fixed side. Then use a toothpick or plastic stick to pull back the spring and drop the battery in completely.
The drive coil is very close to the spring, so whatever you do, don't slip and damage the coil.
Also, don't use a metal tweezer to hold the new battery ( as you may have seen in an instructional video on YouTube).
On the plate or on the plastic surround there will be a mark and a number that will be the maker of the movement and the caliber of the movement from that you can identify the battery required so that you get the correct one for the movement.  If you could post the maker and caliber number it would be helpful..   The advice given by Hector is sound follow that and protect the coil and all will be well.
I forgot to mention that it should be the correct battery (TR621SW / V364). I found a PDF that says that it should correspond with the 5420A movement of the watch.
3 problems occur:
-There is no 'lip' or 'fixed side' that I can slide the battery under.
-The bottom spring is quite hard to press down, so there's a lot of tension on the battery when pushed down.
-The upper spring is way too flimsy to hold any of the tension of the bottom spring. It feels as even if I could fixate one side of the battery, the tension on the upper spring would be way too much.
Am I doing something wrong here? Or could it be possible that there's a part missing, some kind of battery cover that holds the battery down?
/Edit:
I attached the PDF regarding the movement. As far as I can determine, nothing in this PDF indicates that there's a part missing.
5420A.pdf
Edited by Mudos
30 minutes ago, Mudos said:
Roger that, a not so good design. It's a bit of a pain in the ass to get the back cover on with a jumpy battery, but I managed and it runs! Thanks a lot guys!
I've been in such situation once or twice - poor design. Glad to hear you managed it and your watch is running. BZ!
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
