Seiko 5 7009A crystal ring?
...and hi all x2
Also in the vintage lot was a Seiko 5 7009A movement with a hazed or deteriorated crystal. Anyone seen these with the silver ring on them like this? Movement itself just needs a service I think so I'm going to attempt to get it running.
Wow! My cats Rodico hairball. And I don't have a cat...
53 minutes ago, MechanicMike said:
...and hi all x2
I could be wrong, but all you need is Tension (Armoured) Ring - Standard Ring - Chrome Colour - Sternkreuz ATC
https://www.cousinsuk.com/product/standard-chrome-ringed-glass-atc
So they do exist. I was about to think it was some sort of skinny Chapter ring. In my short time doing this, never seen them before. Are they to tension the fit? Or strengthen the acrylic?  Interesting....
7 hours ago, aac58 said:
You can probably find the exact Sternkreuz crystal you need searching by the Seiko model number in this page: https://www.cousinsuk.com/category/filter/seiko-case-parts
I will probably be a XAC crystal (XAC for steel ring, XAG for golden ring)
I've tried: "No items matching or containing '7009-340' are listed in our database. Please check your lookup for mistakes and re-submit."
STK didn't made dedicated crystals for all Seiko models. Only for the few ones that they deemed worth to offer an alternative, many decades ago. A generic crystal can work just fine, ordered by size.
24 minutes ago, Bodo said:
What's the case reference of the 7009?
That to allow searching the Seiko P/N on Cousins, jborel, Boley etc public references. Sometime you can find the part as NOS on Ebay etc, but often the asking price will be 2 or 3 times what the watch is worth.
The best recommendation is to just polish the crystal, which is very easy on acrylic like that
That's why I said "probably". I like the SK quality, but everyone can choose what they like, I was just trying to help. I've found a SK crystal for 90% of the Seiko's I've search for, I'm not sure the watch model in this case is 7009-340x, I really doubt it is despite it is the dial model.
Edited by aac58
Searching with Seiko case ID should be definitely your first step. Sometimes you get lucky ... and sometimes you don't.
When you don't, this page plus your measurements will find you the crystal you need:
https://www.cousinsuk.com/category/watch-glasses
7009-8810. I have them looking. No answer so far.
Same answer I got. So I gave them 7009-8810. See what they say. In the meantime, I ordered a Stella Ever-tite with tension ring at 33.1mm from Esslinger and I'm polishing like crazy to see if I can get this weird white dust-like stuff off the existing crystal.
13 hours ago, JohnD said:
If there are no micro cracks in the acrylic, then polishing the crystal using Duraglit wadding usually restores them to near perfect condition......
Mad polishing going on right now...
found, or finding out, this is very true, indeed. I wonder if they do this intentionally to drive us amateur hobbyists nuts? Same with their movement numbers, model numbers, and every other number combination they can think of...
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
