Rolex 3035 after coa issue
Yallabye
Hey guys, so I’m having a problem with potentially the balance and or escape wheel. Did a complete coa on this movement. Also replaced the upper escape wheel jewel/spring/setting. Now the watch runs but, on the vibrograph shows a lot of time loss. When I press down lightly on the balance bridge a bit it stops, and have to turn it to get it going again. Been stressing me out. Checked all the pivots and jewels and everything seems fine. Any and all info would be very much appreciated!
Edited by Yallabye
Since you replaced that upper (in the plate?) shock setting you probably pressed it too far and now you have no end shake at all. You need a tiny bit of shake there. Less than the train, but more than zero.
Was it a Rolex part, or generic?
There is a bit of endshake. Is it supposed to be flush on the underside or have a very tiny bit of lippage? It is all genuine.
So you got some or little endshake,  just as a test: loosen cock screw 1.5 turn see if oscil speeds up.
 Do you see any shelac keepin pallets put?
You beat me to it, while I was compsing. fast typer.
Sorry can you please explain what the cock screw is and “shelac keepin pallets”
Cock screw is the one that holds the cock down on mainplate, in cases you suspect end stones might be pushing on pivot end( no or very little end shake) you can releive such possible pressure on end stones by loosening the said screw, if the are no end stones, the jewel itself can be pushing on shoulder seat of the pivot.
Shelac is the stuff that acts like glue but wont hurt the base metal over time, it is used on fork pallets jewels to keep them from moving in fork slot, nearly all petrolium base cleaning solutions dissolve shelac rendering pallet jewels loose to move in the fork slot, which ruins escapement at the pallets and can be a cause for a host of escapement disfunctions.
The amount of exposure doesn’t matter- the end shake does. Try Joe’s idea of loosening the cock screw and see if things improve. If so, you may need to press the setting out a hair.
Did you happen to do any hair spring work? At rest, is the roller in line with the pallet fork (straight line between balance pivot, fork and escape wheel)?
Ok so Adjusting the cock screw did help a lot but it is still about 1 minute 45secs losing still. I am going to press out the upper escape wheel setting and see if that makes it better, I’m hoping
out of curiosity why did you replace the entire setting?
normally the above answer would be fine except this is a Rolex watch. Rolex is obsessed with end shake so often times they will have procedures to make that adjustment easily especially on the balance bridge.  rather than explaining the procedure I'm attaching a section out of the manual. You'll notice there's a screw specific for adjusting the end shake. If somebody had zero idea what that screw was for an rotated it that would be the problem.
I replaced the entire setting partly because I was lazy of replacing just the spring itself because whoever worked on it before had broke half of the spring and left it like that so I decided it was easier just to replace the whole thing instead.
I adjust the regulating screw for the balance bridge, and also pushed the setting  in a bit more so the escape wheel has less endshake and seemed to make a huge difference. Within 10 secs.
Checking end shake on escape arbour will suffice. You would get zero end shake, if end stones are pushing on escape pivots.
Removal of end stones so to leave escape arbour unbound might create new problem, that is; you want escape wheel and fork pallet jewels level (both in same plane).
You have high percision gears in this piece, so power transfer through out the gear train should feel effortless.
 Thanks to john's post which shows the design provides an end shake adjustment screw.
Good luck.
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
