maker identification
Lovejoy
hallo all , I'm hoping somebody may be able to identify the maker of a french clock for me ... the stamp is in the form of a 6 pointed star with the letters GC in top half with a religous cross shape in the lower half ... and  on the back plate is stamped   1 million   any help out there please . thanks
5 hours ago, Tudor said:
I'm guessing that cross (on the bottom) is a Swiss cross, and not a religious one.
Otherwise, I'm useless here...
Sorry it was a tad misleading for me to describe it as a religious cross , I meant the shape of it as against a cross indicated by the letter X . cheers
My thoughts are this is German the 1.Million is a trademark associated with a German company called Lenzkirch who where certainly producing clocks in a French style and also supplying other manufactures with movements in other European country's, it certainly has a more Germanic look to the construction the G.C trademark could be a retailer or importers mark.
1 hour ago, oldhippy said:
That is German. As wis1971 has said the finish is not quite up to the french standard. It could also be  14 day duration, those springs are mighty strong. The case might give us more info by its style and how it is made.
I'm in the midst of restoring the case so will post pictures once it's done and re assembled , thank you everyone for your help ...
have finished the restoration ... the case is a fairly standard construction .. no fancy dovetail joints in this one , all butt jointed with nails inserted on a hit n miss basis  BUT it's held up well and required minimal attention ... further research seems to support Wls1971 that it is a German movement  1 million series 22 .. I believe ... I can't help feeling that the case is French made , it's right up their alley but I'm not sure and not bothered either .. have attached a couple of pictures including a side elevation showing the coffin like shape ... Thanks to everyone for their help and research , much appreciated ..
You are correct that case is French and a very nice dial the movement has. Quite a common type of French wall clock.
Here is one I found with just a normal dial.
https://www.bolk-antiques.nl/inventory/clocks/a-very-nice-19th-century-antique-french-wall-clock-signed-friry-laurent-a-bar-le-duc-height-51-cm-price-875-euro-1211593
That's nice too ... I love that shape ... cheers for that
9 hours ago, oldhippy said:
thank you for that .... had a look, nice clock ... if only not so far away ... there was another one listed in Holland that's similar and their translation of oeil de boeuf was " small round window " which makes less sense to me than "antique bull's eye " .... I'd better get the French dictionary out and see ... oh well , never a dull moment where research is concerned . Cheers
A thought just occured .... I have another oeil de boeuf clock that is round so maybe both translations can be applied to this one ?
    • I assume you're using 9415? the concerned with 9415 and I'm attaching a PDF from Omega is too much can cause a decrease in amplitude. This is why you look at what they do they go to extreme lengths to put extremely tiny quantities. so as you've discovered proper lubrication of the escapement increases the amplitude. We've seen it on this group where people are having typically newbies issues and I will ask if they lubricated the escapement the usual answer is no they had not because and once they did they saw spectacular improvement. one of the amusements with lubrication tends to be so many variations. For instance I was in a classroom once and the students all came from for the most part accredited schools in watch repair. So the instructor asked how did we lubricate our escapement's and I don't remember the actual quantity but it's really quite amazing how many people can interpret slightly different ways of doing the same ask. Of course the instructors method was the approved one. This was the place a drop of oil on the impulse face of the exit stone. Allow one third of the teeth to go by and place another drop then another third and your escapement should be lubricated. But sometimes and yes it will show up in the timing machine you'll see in your regular line because if the oil didn't transfer all the way around to the other stone that does cause a issue with the timing machine. Oh but when I was in school we were using 9010 as 9415 did not exist yet although 941 did which is an oil recommended for escapement's. it has to be dissolved in a proper solvent with the right amount of concentration as you want a microscopic layer on whatever your treating. My understanding is the vapor process is the very best but the vapors are not good for human consumption. The reason why the vapor process is nice is that it puts a very very thin coating on versus dipping in a solvent which can vary depending upon the concentration.   8645_WI_40_rules for lubrication cousins.pdf
    • A modern restorer would probably try to inject adhesive as suggested and then weight the repair down. Some damp might have caused the bulge originally.  Traditionally the veneer would have been sliced and glue eased under the two flaps then again weighted back down and refinished once it had cured.  It doesn't look like just an adhesive issue, more than likely expansion of the veneer, worse case it needs a slice taking out. Try some gentle heat on it first , inject glue and weight, to see where it goes.
    • I have seen several mentions of steric acid, how do you use this, I have only seen it in crystal/powder form?
    • Hi @Michael20 I am no furniture man my self but it’s just bits and pieces I have picked up over the years. It just takes patience when dealing with things like the cases but most are veneered plain wood. When they get damp and open up that is a problem
    • I often get an amp drop after i oil the stones with 9415, not sure what difference can be achieved with oiling the teeth.  I guess the oiling surface is very small on a tooth as opposed to on the stones a larger drop might have more drag as the teeth plow through it. I oil with a bristle from a brush now, strangely enough the last movement i oiled five escape teeth and the amp was much higher than i usually get , coincidence ?
