opening a mido oceanstar
gary17
hey guys
i have a mido oceanstar pwerwind watch,which i bought without the glass. Now i come to look at it i cannot get the movement out. I have removed the split crown stem but around the top of the watch were the  dial meets watch case there is either remains of a plastic glass that has been snapped out or some kind of glue. (see pics). I have read that these early midos were rubber sealed in side to make em water tight.
So is it worth chipping all this plastic or glue away to remove the movement or is this watch to far gone.
Would it be worth my while and time to replace the gasket and glass (presuming i can remove it.)
I cannot look up the parts as i cannot get inside to see the caliber, though i have read its a AS movement made especially for mido.
Any hints, or anyone or anyone who knows this watch your help would be appreciated.
cheers
gary
From what it looks like in your pics I would say that it is the rim of the old crystal that has been left behind when the crystal broke. I have had several watches where the crystyal has failed in this manner and you will need to remove it before you can fit the replacement.
It's also worth a close look at the case to see if it has a removable bezel. If it does then that will need to come off before you can remove the movement, and it may make it easier to remove the remnants of the old crystal. It's not easy to see from your photos though.
7 minutes ago, gary17 said:
pair of tweezers and a lot of force
On 10/26/2020 at 3:21 PM, wudce said:
I think you have to remove the crystal first which I think there a tool for that, then turn the crown so the word MIDO is straight and then turn the case over and the movement should drops out
notice two separate answers. I would look really carefully at your split stem both parts to make sure they look like they will function again. The last time I saw this was at work the other watchmaker did exactly what you did. then discovered that it no longer functioned properly. Attempted to fix the problem by closing the female part to get more grip. But as this is not how this was meant to function at least the one we had maybe you'll be lucky it broke.
not all split stems are meant to come apart by pulling a really really hard. Some are meant to remove the crystal and just slide the movement out. If you're lucky yours was the kind to pull out. I'm the skip over why it took us an entire year to fix the problem. Just a reminder not everything comes apart with force. Or for that matter is attempting to close the female part with force wasn't the option either.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
    • I started on pocket watches as they are easier to work on than wristwatches. Many had gold cases, which is why there are so many movements for sale. I was always on the look out for cases, for as Nickelsilver says,  a 16s movement will fit any 16s case* (with tweaks to the stem). I also started hand winding mainsprings, before I had winders. It can be done without damage, but it's quite hard on the fingers.  But you can make homemade winders, see here      * some movements, eg "railroad grade", have a setting lever on the edge of the  dial at about the 1 -2 o'clock, so need a special case.
