I've got a Poljot de Luxe that I'm trying to work on.  I can remove the case back and see the movement, but this looks to be a front loader.
There appears to be a thin bezel holding the acrylic crystal in place, but no place to insert a case knife or other tool.  I don't want to damage the case fighting with it.
Here are some stock images, including one with the bezel/crystal removed.  My watch appears to be identical to these.
Does anyone have experience working on these cases?
Thank you very much for the data sheet on this movement!  I've been trying to find something like this.
Would I use the glass lifter on the watch itself, without removing the bezel?
Because the bezel is the piece that is concerning me.  I don't see a safe way to unsnap it from the case.
If I can remove the crystal directly using the glass lifter, then all is good.
Incidentally, do you know what the correct amplitude range would be for this movement?  I've built one from 10 scrap movements of different vintages, and I'm getting over 300 degrees when the movement is fully wound.  (I've got my timegrapher set to 49 degrees).  I'm thinking that the mainspring may have changed over the production run.  Since my movement is built from movements of different vintages, I'm thinking the mainspring I picked may be too strong.
Very nice.
I have a Sekonda which is somewhat  similar but not nearly so well preserved. In my case, the bezel and crystal pop off in one piece. It splits about the line I have indicated.
Before you try this though examine very carefully with good magnification. You may find a small indent/recess to insert the blade at.
If this is indeed the way it is constructed use a very thin blade, like a safety razor to push into the gap and separate the two parts. You may need to push a second one in beside the first to get enough of a gap to insert your case knife and you should then be able to pop the thing off
If there is no recess to inset your case knife, then Insert your first thin blade in the line between the lugs where any accidental damage will be less obvious, but proceed very carefully so you don't do any damage in the first place.
Once the bezel and crystal are off, undo the two screws holding the clamps that hold the mechanism in and it should pop out of the front.
If you don't remove the bezel, but just the crystal, then the dial may be trapped behind the inside curve of the bezel and this may prevent the movement from coming out.
Edited by AndyHull
On my Luch 2209 there is a small slot to pop off the bezel and crystal together as one unit, directly opposite the crown. I used a small screwdriver. I am pretty sure the bezel and crystal should come off as one piece - I would not attempt to separate them!
The design and dial looks very similar to this one from the 1966 catalogue.  The hands and case colour are obviously different though.
Edited by AndyHull
The results of OCR and translate on the 1971 pdf description of the 2409...
"FLIGHT" 2409
MEN'S WRIST WATCH WITH CENTRAL SECOND ARROW AND ANTI-IMPACT DEVICE.
Movement caliber 24 mm for 17 ruby stones.
The shockproof device reliably protects protects the balance axis from damage during service tea strokes.
Siscial alloy hair.
The winding spring is made of stainless steel.
The oscillation period T is 0.4 sec.
Average daily variation in absolute value rank 45 sec.
The duration of a stroke from one full spring winding for at least 36 hours.
Stainless steel enclosures, chromium-plated bathrooms and gilded - 20 microns.
Dials.
Silver, gilded and with black pickel.
Figures and signs are embossed, milled.
Black scales, gilded hands and nick2- lyrovannys.
Your guess is as good as mine as to what "lyrovannys" are.
The 2609 translation is a little less clear
teahouses at the Dafs, _ | ye
non - yen screwless.
Special alloy hair.
`` The winding spring is made of special stainless
° drifting alloy $ -shaped.
Oscillation period T =: 0.4 sec.
Average daily rate. by absolute value
`rank 30 sec.
o The duration of a stroke from one full
`- ca 'chrome-plated and gilded -20 microns,
_- square-oval and round.
° .Silver, gilded and
° covered with black nickel.
Numerals and hour signs embossed and framed
_ ..
grained, _ golden and silver
-. rowdy,
t.
The scales are black _ and white. Gilded hands
and black zveg,
"ROTUOT› 2609
 The jist though is that they are similar. There is no description of the 2209 in that catalogue unfortunately.
  On 10/8/2020 at 10:04 PM, AndyHull said:
Very nice.
Expand
That worked beautifully!
I had to look really closely under a 10x loupe to see that there really is an almost imperceptible area just where you indicated.
I was able to carefully insert a case knife and the bezel popped off without any effort at all.
Now to see if I can replace the movement in this watch with the one I've created from scrap movement parts.
  On 10/9/2020 at 5:50 PM, JohnC said:
By the way, just a word of caution on these 2209 dials. I have always been suspicious of the ones that have the double-marker at the 12 instead of the triple. This link is suggestive but maybe not conclusive. All of which isn't to say that it is not still a good watch - just depends on your preference I think.
https://www.2209watchmovement.com/brand-specifics/luch
Expand
I emailed the owner of that site with the details on my watch.
He's pretty sure it isn't NOS, but is a frankenwatch created using a 2209 movement with a new case, dial, and hands.
I'm not too peeved about that.  I'm not averse to getting a replica using an old movement.  I just wish the seller had been honest about it.
Whatever it is, franken or not, its certainly something I would wear.
If that dial is a replacement, it is an excellent one, find me the person that created it. In my experience, most franken dials are pretty poor, that one looks too good to be franken, but I may be wrong.
How is the rebuilt mechanism doing?
What is the issue with the one it came with?
Edited by AndyHull
The movement that came with this watch has an amplitude problem that causes it to gain a lot.  My timegrapher isn't even able to sync to it.
I didn't care try to work on the movement without more knowledge and experience, so I ordered scrap movements of the same type to work on.  I've been able to build a movement from those.
This built movement works better than the one in the watch, but it isn't perfect however, its amplitude waxes and wanes, and the watch gains and loses time along with the amplitude changes.  For example, it might say 278 and +3 seconds, then jump up to 302 and +22 seconds, then down to 265 and -13 seconds.  I'm keeping it wound and on the timegrapher to see if this settles out.  I've also demagnetized the movement.  All the parts have been cleaned and I've oiled the movement with D5 and 9010 in the appropriate locations.
I've not been able to get this watch back together again yet as its dial feet are friction fitted and are loose in the movement.  I've ordered some adhesive pads from Esslinger's.
Here are some pictures of the case and dial that I've attempted to take with the macro function on my old camera.  They've not come out great, but they may be good enough for an expert or two to give me an opinion on their provenance.
Edited by LeeReynolds
Re. The variable amplitude issue, check the amount of sideshake in the barrel arbor and make sure the barrel isn’t hitting the bridge or the main plate when wound. I had a similar problem with this movement and it turned out to be barrel arbor bushing wear.
If you really like to learn more (in-depth) about Russian watches (and the "fakeries") I would recommend to have a look on the WUS-forum: https://www.watchuseek.com/forums/russian-watches.10/
This is a good thread to start with or to read: https://www.watchuseek.com/threads/q-a-expertise-thread-is-this-watch-legit-or-a-franken-part-3.4977267/
Wish you Suc6 and perhaps see you there ?
Edited by Endeavor
Expand
I never thought about it being a problem with the barrel.  I'll definitely look into that.
  On 10/12/2020 at 3:05 AM, JohnC said:
Also about the dial feet. Are you sure you are not missing dial screws? On mine they screw in, not friction fit.
Expand
I'm 99.9% sure.  Some of the movements I stripped down had dial feet still stuck in the main plates.  These feet were in there snug.  The dial feet locations aren't on the very edge of the movement, but within the interior.
I figured out what is wrong with the original movement in this watch.
It's balance cock is warped.  The portion of the cock that holds the end jewels is curved upwards slightly for some reason, which means that the angle between it and the balance wheel stem is not 90 degrees.  Hence low amplitude.
I discovered this after doing a complete service on the movement, including the end stones, which did nothing to improve the movement's performance.
So I've ordered another 10 scrap movements from Etsy since none of the good balances I have are a match for this one.  I'd prefer to put on one that is the same vintage as the warped one.  I'll also look to see if I can fix this balance cock, but I'm not going to hold my breath.
I may also be able to build more working movements from the 10 scraps I'll be getting.
  • Similar Content
    • Amazing 🙂 I am very happy to hear this. I shall keep my eyes open for some red threadlock to go on sale and pick up a little tube.  Thank you all for your assistance and wonderful first exposure to this site and community!
    • Just a reminder we have a section just for these sort of things. https://www.watchrepairtalk.com/forum/74-new-to-watch-repair-safe-zone-for-learner-watch-repairers/ When reassembling a watch as others have pointed out it's wise to check the functionality of components as you go. So in other words before the pallet fork goes in or even the balance wheel you can attempt to wind the watch and make sure the gear train spins nicely. Then you can put the pallet fork in wind up the power and see that the pallet fork snaps each time you push it back and forth in other words things need to be done in steps not all assembled and then discover we have a problem. Although unfortunately sometimes that does happen and sometimes the problems do not show up instantaneously.
    • Now One of the things that's always helpful when asking for help for any watch would be which watch exactly are we talking about? Because the definition of small pocket watch doesn't exactly do it for us. Do we have a name of who made the movement and typically that's not the name on the dial.   I find your quote really quite fascinating? Lacking knowledge of the movement is quite a hindrance in this discussion. Then there are companies that make balance completes for replacing in watches. No need to try to order from the manufacturer as that isn't going to happen anyway. Then I think it would be helpful to clarify something? You're helping the charity shop I'm understanding at the extreme the lowest price to achieve what goal? So in other words all you have to do is get the watch to run for a few seconds a few minutes long enough to sell it and clear it out and make a profit correct? What I'm getting at here is were going to throw conventional watch repair practices out the window and go with whatever we need to do which means you could just Glue with whatever you have. It's not the recommended procedure but I'm interpreting were not using the recommended procedures we want to do fast quick repairs I get these things out the door correct?
    • That does look promising to be repairable without having to start threading and tapping things.
    • To be honest I never use calipers when bending a balance bridge as I'm checking the end shake as I do it a little at a time. Now that you've bent your bridge how Has it changed your end shake?
