Hinging Inca spring
jdm
This has been discussed already but I will restrict it to a simple question. Any real chances of bringing it in place with upsetting the block?
I was thinking of keeping the spring vertical with rodico and place it diagonally in the opening.
Not fun and not easy considering  the need to do this within a clear bag.
Hi!
This happens sometimes. You need to reinsert diagonally one leg at a time very carefully. Under magnification works best. I would personally do this with fine tweezers, not actually holding the spring, but working the ends in carefully as it rests on the Incabloc.
1 minute ago, DrG said:
Hi!
Forgot to mention that there is a very high probability that the clip will fling out a couple of times.
Funny I just did one of these they can be a pain. Was I did was to hold the the spring vertical with my  tweezers  with the tabs in line with the grove then I turn my movement holder a 1/4 turn and it felt right in. You have to remember they enough room to do this since the spring with hing up for service. I did do this work under my microscope.
OK, it went in. First i cut an hole in adhesive tape which I placed to cover That is essential unless you like the spring to enter the movement at some point. The spring wouldn't go all the way down vertically, the chamfers made it jump all over the place. Looking carefully I saw some space on both sides of the cut, just above the regulator ring, so I placed the spring horizonally with the smallest moves pushed it toward the center. Next drama was removing the tape without touching the spring. Oh well.
is this a Chinese clone or original? the reason for the question is the Chinese skip one of the manufacturing steps. If it's an original spring it is not supposed to come out typically without disassembling the setting. on rare occasions you will have an original one does come out and then it will go back in usually with difficulty.
Genuine ETA in an Oris. Google for Incabloc images to see what great variety of shapes the block can have. From that I suppose that some are more prone to the problem. And the microscopical hinges may not be 100% perfect.
Give me Seiko Diashock everyday, really.
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
