Alf. W. Fuchs pocket watch info.
markr
I can't find any info on this name. Found at a yard sale yesterday.  I assume it's a jewelers name on a watch made buy someone else. Any help I.D. the movement or any other info appreciated. It's running great. Double hinge back.  Not solid gold.
I think we might be looking at an Illinois grade 228 movement which, as you've already observed, has been branded by the jeweler who likely also cased it.  If I have time I can look up the case marks and see if I can give you the casemaker and gold content.
https://pocketwatchdatabase.com/search/result/illinois/1996499
1 hour ago, markr said:
It even has the same finish on the bridge. I'm not a pocket watch guy but I took a chance at $30.  I hope I did ok.
Well, the case is marked with marks I've seen before; there's some definite gold content.  At a guess, at least 14k.  But I think more than that. And 15 jewels are nothing to sneeze at.  Standard compensating screw balance, but the regulator also has the fine-tuning setup.  And it has a very pretty dial also.  And you tell us it's running great into the bargain.
Yeah, man!  You did better than great.  That's a steal for $30!  Where are these yard sales you go to?!?!?  Holy smokes, man!  I haven't been that lucky in an age and a half!
  • Thanks 2
Sorry not solid gold, but 'gold filled', see HERE for more information....
Good research there, JohnD.  I knew I'd seen the Star-and-Moon stamp before.  I should have remembered "Crescent" case (as in 'crescent moon') So it looks like not quite 14k after all.  Still, even many of the gold-filled cases can fetch a nice price, depending on workmanship.  And this one has a nice color, if the lighting is true. In all, I know I myself would readily pay more than $30 for that watch. But I concede, I tend to place greater value on the movement, rather than mere aesthetics or precious metal content.  Not all buyers do.
Edited by KarlvonKoln
Edited for clarity
Thanks everyone for your help. Not being a pocket watch collector this will probably be a flip or trade watch for me.  You all are amazing with all of your help and knowledge.
Hmmm...I think I may just have to keep my eyes peeled for it (after I see what my next paycheck will look like).
No no no no no.  I have enough of them.  I promised myself.  But that one is so pretty.  Ahhhh, dude, yer killin' me.
Made an addition
You all did such a great job on the last yard sale find I'm posting this weeks find. I bought a Seiko sport and a Woman's polo club for $1 and they gave me the pocket watch for free because it was broken.  Is it gold?  I need a stem for it and the 937 in the photo. I tried to find tech sheets for them so I could find the parts number but no luck. Are they 2 piece stems?  I also need a stem for a ladies Hamilton 605. Any help on parts numbers so I can find the 3 stems would be much appreciated.
The secret to yard sales is to ask twice.  The first time you ask they automatically say no.  When you ask are you sure you don't have an old watch inside that is when they start to think and then they remember. I have gotten hundreds of watches that way. Got a brand new Tissot with box and papers this weekend for $40.  A Zodiac last week and a vintage Movado the week before.  Getting cold in Milwaukee.  Yard sales will be ending soon.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
