Good Afternoon,I hope you are all keeping safe and well during this tough time.I wonder if anyone can help me with a small problem I have.I have just purchased a new Bergeon Cannon Pinion Remover and it will not remove any cannon pinion's from wristwatch movements as when the lever is fully depressed the collet will not close enough to grip the pinion it just is too big for watch pinion's.It works on large pocket watch movements but not on wristwatch movements of various sizes as I have tried 5 different movements with all the same results.I enclose photos of the new tool as received from H Walsh I await any replies before I send this back for a full refund. Regards,Seth.
It seems that the Bergeon doesn't remove pinions below 1.00mm dia so it's back to the pinvice and this new Bergeon tool will be going back for a full refund.
When I bought mine the information on CousinsUK clearly stated: "for small and large watches” and ”adapted to all calibres”. It was not, and Cousins changed the description (added: "Can lift cannon pinions diameter Ø1.00 to Ø1.80mm") and refunded the money. I record a video about it...
Once in a while you'll find vintage cannon pinion removers on eBay. I did and every time I use it (a K&D) I marvel how smooth and exact it it is even for very small cannon pinions.
Hi to you all,just a quick update on this Bergeon Cannon Pinion Remover 4854, I emailed Bergeon to say how disappointed I was that this item will not remove pinions of 1.0mm and less and Bergeon have said that this 4854 Cannon Pinion Remover is for pocket watches!! They suggest that I use either a Presto type remover or Hand levers (hairspring collet type) and they have even enclosed their part numbers and PDF images of these items!!!! Regards to all and keep safe,Seth.
Good Morning to you all and I hope you are all keeping safe and well.Just a quick update on my Bergeon Cannon Pinion Remover,l decided to keep the tool and investigate if I could alter the collet size somehow.Well after disassembly of the tool and looking at the collet size I found out that with a small alteration of a Dremel collet using my Lorch lathe I think I might be on to a winning situation!! I will keep you posted on this.Regards to all and keep safe,Seth.
Cut a piece of thin aluminm foil, like 1.5mm by 3mm, warp it aroumd a screwdrive about the diameter of canon pinion, role as you would a cigarrete, you are making a tube of aluminum, place the tube on the CANON pinion, you have increased diameter of the canon pinion by the tube's thickness, the tool grabs the bigger diameter.
It works.
Good luck.
  • jdm changed the title to Bergeon Cannon Pinion Remover
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
