Another Request For Help From Newbie
Johnvsd
It was an accident that i dropped the watch, and the stem is broken. The broken stem is deeped inside the watch. I need your expert advise of how to take the broken stem out from the engine without taking all the parts from the watch. Many thanks in advance. And have a nice weekend gentlemen.
Welcome to the forum. Not 100% sure (not worked on one of these), but I would loosen the outermost screw to the right of the stem and try to withdraw the stem remains with fine point tweezers, failing that it may be a case of pressing the stud down to the left on the stem.
Hi,
   The screw that people are talking about when I look at it just looks too big to be a set lever screw so I would try pushing down on the stud to the left and pulling out the stem with tweezers. That's easy to say because it doesn't look like the is enough stem left to grab hold of. If the little stud doesn't move then it has to be the screw. As everyone said loosen it a bit but then push down on it some to loosen the set lever and hopefully the stem will fall out. I'm afraid though that you may have to go in from the dial side and remove most of the keyless works to get it out.
Charles K
When asking for help it would be nice if you would give us the model number. So pulling out one of my books an automatic watches as a guess it look like a longines 19a Or perhaps a 19as. So I've attached Your photograph with a circle as to where the set lever screw Is.
Then googling I found some helpful links for you with lots of pictures.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?12&ranfft&0&2uswk&Longines_19A
http://archive.horlogerie-suisse.com/vintages/longines/longines-calibre-19A-14350209.html
http://watchguy.co.uk/service-longines-conquest-calibre-19as/
my apology for that. Yes it is Longines 19A. I tried to release the screw, and use every small, sharp to pick the broken stem out. However, I failed. It is really stuck inside. Thanks gentlement.
Just a thought guys, is there any chance that when you back off the screw identified by JohnR, that you would then push down on the head of the screw or what appears to be a button, to release the stem. I'm sure somewhere down the line I had to press down the screw head to release a stem, after backing it off. It's certainly worth a try before pulling the keyless work apart.
If you really can't get the stem out and disassembly the watches definitely not in the beginners category a compromise would be to remove the dial. The setting parts are underneath and you can usually get the stem out sometimes if you're lucky without having to remove all the setting parts.
I agree with John, if you have not disassembled watches before, take it to a watchmaker.
Regarding what I said earlier about pressing down on the screw, I have just ahead a look at a picture of the keyless work and it looks like it could be a possibility. The setting lever spring is pressing down on top of the lever and preventing it from releasing the broken stem. If you back off the screw a couple of turns then press down on it, it will push against this flat spring and should free off the stem. If you look at the middle top of the picture you will see the back of the screw in the centre of the lever with the flat oddly shaped spring to the right of it. It is this spring that is preventing the lever from disengaging from the stem.
I will be sure to try that. Thanks
Keep us posted!
Do not back the screw all the way out or you will have to take it for repair. That said, if it doesn't work with two turns, keep trying another quarter turn at a time until you are successful or not. Bearing in mind that a watchmaker job is looming on the horizon anyway.
I believed when I dropped the watch, the stem was broken and benched inside. I tried the way you said, and I found out that the broken half inside is very curve down. I will take it to the watch repairer in my local for help. Thank very much.
Hi,
A bit late with this reply...
I made a couple of little tools for broken stems using stem extenders and a couple of old watch crowns but there has to be a bit of the thread left in order to be effective...
Hi,
Great idea Darren! :)
Hi,
That would be nice to have those
Hello John,
I think you have a decision to make whether to tinker or not.  If you pursue this you will probably need to start buying some stuff to make the tool like the ones Darren talks about, but in your case you would need to first find out the tap size of the stem for your watch either from reference material or perhaps you still have the crown with some remnant of the stem in it that you can size.  Then get an extender to fit the thread and you can remove the remnant from the original crown to use the crown and in that way you have your tool.  Note that to use the extender there must be enough room to accomodate the female end.  They cost a couple of quid on the Bay
If something has gone bad inside the keyless works due to the dunch and the tool does not work I fear that removal of the hands and dial is the only way to go so then you come to the decision whether to tinker or not as if you do not have the tools for hand removal getting them off with tweezers or whatever is not really a good idea. and dial protection is important to ensuring the looks are not marred.  At least with the right tools you have a chance.
Either way there will be loads of help available from the forum.
Cheers,
Vic
Just some additional stuff that may help.
I think that you need an extender that fits a stem size .9mm which is referred to as Tap 10 so the extender would have to screw on to a Tap 10 thread.
If anyone finds fault in this please don't hesitate to correct me - its all part of the learning process.
Cheers,
Vic
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
