Some new clocks to the workshop
Squiffything
Hello guys it’s been a while and life has changed here in Squiffyland.
i lost the Saddlemakers apprenticeship having been furloughed since March. Not enough work coming into the workshop. Had to have the dog put down after a growth was found which ruptured his spleen. Oh and Mrs Squiffy has decided the wants a separation which will probably mean I will lose the house and therefore my shed And workshop/office.
......still it’s not all bad, I had a nice little run down to our local antiques barn and was allowed to have a rummage in the back shed for projects (cheap and the sort
of stuff they will not repair). Came across a couple of possibles with potential.
Firstly an Art Deco style mantle clock.
Then an old American wall clock. The wood on this one needs some veneer work and the glass has some paint flaking with one section missing and the usual makers sheet has all but gone so no idea who it’s by. I have managed to get both running and chiming. It’s and old one probably around 1840 - 1860’s run by weights and pulleys with a car starting handle instead of a key!
Finally a large pocket watch. I think this one may have had it and definitely beyond my scope. My best guess is that it has been left on someone’s mantle piece over the fire and this has taken its toll. Amazingly it still keeps perfect time!
Well it’s not as well as it could be but life for a wannabe Clock repairer still goes on and I keep trying to fix/make/repair things and always try to keep smiling ?
Nice to hear you are looking on the positive then the negative with all the things that are happening in your life squiffything keep up the good work with the clock repair not seen anything like that large pocket watch before think oldhippy would have a few problems with that one ?
Hi Karl, yes it is reverse painting though the paint is now very dry and coming away from the glass. I’m reluctant to do anything with it which might make it worse. The good thing is it’s one place and all one colour so if a definitive match can be made it could be filled. Not sure what to do about fixing the old paint to the glass.
The wall clock is called an American Ogee, that is because of the shape of the front outer edges curved into an s shape. You are not far out with the date, they started in the 1830's. The glass painted panel's can still be bought from new. As it runs on weights I expect it is an 8 day.
I believe it’s a 30 hour ogee (or OG) I’ve found a few references from a few makers with the same picture. It’s the Capital at Albany NY. It would be a shame to replace the original pic. It’s quite primitive which adds to its charm. A couple of close-ups to show the damaged areas (or as the antique sellers would call it, ‘its patina’ )
Hi Luiaza, yes it looks familiar on the face.
my understanding of these were that they were mass produced out of cheap materials so that the poorer folks could afford a time piece in the home. The case is very low grade wood with a veneer applied it also used the cheaper pressed metal mechanism case again making it cost effective to mass produce. I’ve got some suitable veneer to tidy up the wood and I’ll re-stick the areas that have bubbled up. I think it’s a leave the dial alone situation on this one and the juries still out on the glass until I can find a solution to reattach the lifting paint.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
    • Yep, that's exactly how it should fit. The reamer shank is tapered and the socket in the spindle is also tapered so that the one centers in the other and is gripped tightly. If there is any wobble when the reamer is seated as far it will go then there is a problem. The cross hole in the spindle is to allow you the push the reamer back out again. If the reamer seated much deeper then it would limit the access for pushing it back out again. Here is one of mine for comparison.
