Hi, New comer - Tommy from Hong Kong
geeboo
9 minutes ago, Nucejoe said:
Would you happen to know about watch manufacturing or fabricating companies in your locality?
Hong Kong is one of the three watch capitals of the world. The fair is interesting to visit. Below a link with some 300 names
https://event.hktdc.com/fair/hkwatchfair-en/Event-Exhibitor-List/HKTDC-Hong-Kong-Watch-and-Clock-Fair
  • 5 months later...
