I must be mad, I found one of those ladies silver fob watches in a draw earlier today, you know the sort of thing, there are hundreds of them around, you usually see them at most of the antique center's.
Anyway I was board so I thought have a quick look, I found one, it's not be looked at for donkeys years.
The bow and pusher was missing, the one you push to open the back so that you can wind the watch, and the the center post and hand settings square was missing, oh blast can I be doing with it, apart from the fact that it's probably 140 years old, I'm sure it will be worn out.
I'm not sure anyone else does these sort of things for fun, but I thought I've started now, I will let you know when I've put it through the cleaning machine next week if it runs.
Nice.... I hope you get it going!
Great to see the Geneva stop work is still in place, as some watchmaker's used to remove it to gain a little more power reserve, but it does have it's cost...
Hi  Its a five bar cylinder movement,  Delicate things but great once done just be careful with the cylinder balance the pivots are hard and balance spring blue steel and doesn't like being mauled about.
That movement is more likely to be Swiss. Years ago you could buy the center shafts, don't think you can now. Have a look on ebay but I'll tell you no two shafts are the same, you might be able to get hold of one and adapt it to fit. All the above by members about the movement is correct.
Its more like millions of these movements not hundreds. :D
If the center post is missing that means the canon pinion and hour wheel are also missing. Doesn't mean it's a fun repair though- just need to make a canon pinion and hour wheel, an enjoyable afternoon!
Thanks all for your thoughts.
As luck would have it, the cannon pinions and wheels were all there, I made up a new post for the cannon pinion, managed to file down the hand setting to make it the same size as the winding square.
The watch goes like a train, gains 4 minutes a day, so I'm not complaining, also I found a new loop and made up the pusher for opening up the back.
I know it wasn't really worth doing, I just did it because......
That's freaking awesome, many pros won't work on such watches because they say it isn't profitable, but I think they are more scared of the unknown (and many pitfalls such watches might contain, fair enough). Killer job and like OH said bravo!
That is so cool!  I like working on those.  I tend to troll Etsy for vendors selling "steampunk" parts.  You can sometimes get a whole verge & fusee movement there.  I got a bunch of old hands, crystals, arbors, stems, keys, you name it.  And they often get used on something I work on.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
