Hello dear watchmakers.
I am trying to train myself to polish a watch.
I got myself a Dramel 3000 and put a little pelt wheel.
I applied green polishing paste and tried polishing a caseback in speed of 5 (out of 10 )
With Dramel, I tried polishing up and down then from side to side.
I did get some scratches and even some printings out but the caseback is left with foggy traces.
What have I done wrong and how should I fix it?
I have attached the photos of polished caseback. (I forgot to take photo before doing the job)
Great thanks.
Avoid green Dialux. Use orange Dialux for major defect and dings, grey for scratches. Finish with blue Dialux on a muslin wheel.
Work is much easier and faster if you place the rotary tool on a fixed stand.
I don't know if you may post links to youtube here but I think this is an excellent video on polishing. I have not done any polishing myself yet but that is perhaps the next step for me (after mastering servicing a chronograph).
And here is this forum full context of the previous four times that video has been posted in the past. I think there are a few more.
I don’t think you’ll get great results polishing the caseback with the Dremel in that way. What might be possible is to mount the caseback on a dremel tool bit (something like a cutting disk) using adhesive and use it like you would a wax chuck on a lathe. You would need to centre the case back as the adhesive was setting to get it to turn true. You can then turn the caseback and use a static polisher of your choice such as a buff stick.
Another option for a straight-grain finish is to polish it under-hand on abrasives.
I did that many times, achieving perfect results, using the products and basic technique mentioned above.
Quote
Sounds very complicated for such a small task.
Anyway the OP has a non-starter caseback at hand, the printed writing is already all gone beefore getting the weels and compounds right. Unfortunately one needs solid quality watches to get solid results.
Edited by jdm
Well, I suppose it depends on what you define as “perfect”. I don’t think you could easily achieve a flat/even polish using a Dremel in that way, and the photos posted above show why. You could possibly buff, but in this case significant material needs to be cut, assuming the intention is to remove the printed text.
I do own the same Dremel as shown above, but I always mount cases and case backs on a lathe to get results which I would expect from a watch leaving the factory.
  • Confused 1
I managed to find a piece if plastic pipe with a decent wall thickness that just happened to fit over the screw thread on the case-back (of my Omega Seamaster vintage 1967) and which also fitted over the outside of a small chuck for an electric drill.  Ran the drill at its slow speed and used dialux compounds (can't remember which !!) on a cloth backed by a wooden spatula.  This gave a good polished finish with no lining/marks.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
