Hi all,
Hopefully I'm on the right forum this time!
Thought while I was struggling getting my first project back together, I would try a pocket watch as I'd read they were a bit easier, so I bought this off Ebay.
I've fallen at the first hurdle as I can't work out how to get the back off! Don't think it screws off, as I've tried without success, so thought it must prise off, but again no luck. I don't want to apply too much force, just in case it actually does screw off. Anyone any experience/thoughts on this please.
Don't be surprised when you open up your pocket watch it might not have a pocket watch movements. It might but the dial is physically smaller which makes me suspicious it's probably a smaller watch. Then as far as opening the case we really need a side view. Probably it's a pop off back but if it is typically if you look around the edge with the back seam meets with the middle part you'll see a indentation for inserting a knife. If there is no indentation than it would be a screw off back.
Money's on a pop off back
And you'll find something at the lower end of the pecking order inside ... like a pin lever (watch) movement. Still great to practice on though.
