Zero chance of getting a spare part, so either a new movement or take the power reserve function from the watch. This is an intermediate  wheel assembly from the  power reserve train, which had one of the wheels in the assembly with 3 missing teeth. With nothing to lose,  I have decided to have a stab at a repair. Next stage is to clean up, put the little sub assembly back together and then try it in the watch. I have no idea if it is going to work!!!
BTW, just to explain. The wheel with a section cut out is a doner from my spares bin which had the closet tooth profile. I cut a section of 3 teeth and implanted (soldered) it into the damaged wheel.
Looks good. Did you try “topping” the repaired wheel, ie. checking if the new teeth are relatively proud of the original teeth and stoning down?
Must have been a really tricky job at that size!
A good try. I have blown the photo up to take a look, the teeth are too high and you have the wrong angle each side, it will be hard for the teeth to mesh when it makes contact with other teeth. I think it will jam up.
I think @oldhippy is right.
From wrestling with hairsprings this is one of the trickiest repairs to do, and when doing it one whish one saved the previous discarded part in the “good to have in the future box”.
When it comes to replacing the teeth the donor piece has to come from a wheel not only with the same diameter but also the same type of teeth and depth on them, this is so you will get the correct amount of freedom for the wheels to rotate in a correct way.
Even small differences like these ones will make the wheels not to run correctly in the length.
Another thing to consider is how to put the new piece in place. One should avoid making a rectangular shape to fit with and instead make a “dove tail” shape with a precision triangular file.
Since the teeth on the wheel is subjected to lateral driving pressures a rectangular shape will eventually cause it to wriggle free and fall out, the solder hasn’t a very good mechanical resistance.
This is just some small tips and tricks to think of when repairing wheels.
  • Like 5
Thank you very much for your comments. I agree with you all. I am sort of hoping that I might get away with it as all the train has to do is rotate the power reserve hand, and most of the pivot holes are not jeweled. I suspect you are all correct and it will not work.  HSL, you are spot on, as I did not have an exact match of wheel, and then once I got to the soldering stage, when I saw the gaps due to my dodgy workmanship, I wish I had a mini milling cutter (a machine I do not have). I found it hard to be accurate with a file as the 3 teeth are about 0.8mm across, so it was difficult to hold. Over the weekend I should be able to get back to it to see how it fairs
Hi, it worked absolutely fine first time with no adjustment.  I checked it over a couple of weeks and it never looked like it would cause any problems. The appearance was sub-standard and if I had to do it again I would try and prepare better before soldering to make the appearance better. Thanks for your interest
  • Thanks 2
That's awesome. In non-power delivery gearing, often you can get by with some serious leeway as long as nothing binds. A friend of mine worked at Breguet around 2000, he had an 80s vintage watch come in with two brass pins in the minute wheel where teeth had stripped off. His boss said ,"if it works, leave it", which he did and promptly quit haha (Breguet has massively improved in that time btw).
    • Sounds like you've either got a short somewhere or excess friction that's draining the battery. Are both insulators still under the battery.
    • I have only made screws down to M1 & 14BA & I had trouble getting the slot in the centre of the head so I made a jig to help me be more accurate when cutting the slot, here is my video.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
