Mainspring GR code
TibiV
Hello,
If someone can help with a GR code , on Cousins UK those books are obsolete and no more available to buy, or if you know another website to determine this code for a broken mainspring
Dimensions are 1,3 - 0,2 - 270 - 9 in mm  and has a hole so TR - those dimensions cannot find on Cousins, so any ideas will be welcome.
It's for an PP for ladies , beautiful watch.
Thank you in advance,
Stay healthy
BR
Tibi V sr
I was reading this again and there is no way a .2 strength, 270mm long MS fits into a 9mm barrell. Beside .2 is way too strong especially for a ladie's. That before considering that the smaller height GR lists for holed end is 1.5. So you should measure it again.
Woops  Nickel "fast fingers" Silver beated me on the finish line!
Hello,
It'a PP , way out of normal range, good idea I will do the measurements again.
It's first time to change a mainspring
First service was made in 1953
Thank you for advice
I never saw something like this , I will attach some photos as soon I will have time, I hope you will enjoy it.
BR
Tibi V sr
Just a couple of things-
PP I'm guessing is Patek. This is going to be a delicate watch, balance pivots are likely 0.06mm or so. For that age of watch it may or may not have shock protection, either way you'll be dealing with some tiny parts. Hairspring will be very very fragile. Be very careful especially if you don't have a lot of experience on very small pieces already.
The mainspring, having a hole end, will also have a "T", either as part of the spring (attached) or as a separate piece. Don't try to use a hole end spring without the T, the spring will almost certainly pull off the hook and/or damage the hook. A modern tongue end spring will work though.
For ballpark thickness you can take the ligne size and make that hundredths of a mm. 7 ligne watch, 0.07mm spring. 10 ligne, 0.10mm. It's a rough guide but you can see that 0.2mm would be about a 20 ligne watch, haha.
Also, be careful.
Hmm, that's what was in there? What's the movement diameter? 0.12 is still pretty strong for anything I'd call a "ladies" movement. For example a Peseux 7001, at 10.5"' takes a 0.11 or 0.12 depending where you look, but at 21,600 does need a bit more power. A typical 10"' LeCoultre from the same period as your patek takes a 0.10 or sometimes even thinner. These are what would be considered smaller mens movements.
On edit- Ah, ok, you actually have a barrel with a 9mm inside diameter? Ok that's not what would typically be called a ladies movement even if in a ladies watch. The one you just posted coud work but it's anyone's guess if the T from a Waltham spring lines up.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
