I was asked if this watch was a good buy on watch finder by a colleague. I had to say I suspected it had not been serviced correctly and selling at £16,675 retailing at £10,850 you expect it to be perfect. I have not inspected it just noticed the obvious. Would love to see what you guys think.
5 hours ago, KarlvonKoln said:
Out of curiousity, what's that extra hand do?  If it were a Vulcain Cricket, I'd think it was an alarm indicator, but I see no extra crown or pusher.  And I see no days of the week on the chapter ring.  Extra stopwatch hand for diving?
As @Marc stated, it shows a second time zone.
More details here -> https://www.rolex.com/watches/gmt-master-ii.html
As to whether it is worth the asking price, I'm probably not the best person to ask, however if you want a few similar examples to get a feel from what the asking price is likely to be for a good example, you could do worse than compare with Watchbox - https://www.thewatchbox.com/gb/en/search/?q=rolex+gmt+master&lang=en_GB
or Watchfinder - https://www.watchfinder.co.uk/Rolex/GMT Master II/watches
Obviously their prices will be higher than you might expect from a private sale, since they will almost certainly have serviced and prepared the watch to a pretty high standard.
  • Similar Content
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
