Hello from the UK!
Hello Everybody,
I’m from the UK and work in Finance in the midlands for a large logistics company. I’m a fairly handy person and so decided to take up a hobby in watch repair around two years ago after being interested in watches for some time before that. With it being relegated to whenever I get some free time outside of work and family, progress can be slow and some projects can take some time. Despite this the learning and developing is great and I’ve slowly acquired tools I could have only dreamed of owning at the start of my journey.
I find the idea of bringing something that seems irreparable back to life as a thoroughly rewarding and relaxing one and so found it to be a perfect fit even despite the frustration at times!
The fact that I’m only posting now for the first time after a year of visiting the forum almost daily is a testament to the wealth of knowledge and helpful community on this forum so I’d like to thank everybody that has contributed in the past. It’s helped me out of plenty of situations I was stuck in and I’m sure it will continue to do so in the future.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
