Hello there, I'm from the UK, Preston in Lancashire.
Due to coronavirus and various changes in my industry and life over the last year or so (I was a 3D animator and CGI type person, working freelance), my career looks like it is over and I am considering retraining into watchmaking as I have been a minor tinkerer (modifications to Seikos mostly) for quite a few years, and have been a bit of a watch obsessive for most of my life.
I'm a handy person, good at crafts and DIY, electronics, etc., and I'm hoping to pick this up over the next 12 months or so and then offer servicing to paying customers... I don't know if I'm being naive here? All the same I need something to focus on in the interim as the current state of the world isn't the best for my mental health.
I'm starting from zero, no real watchmaking tools except some cheap Chinese bits and pieces I've used for mods, budget of about £500 to get some starter tools (was hoping I'd be able to get some decent stuff from the start, at least for the most regularly used bits), and, well, apart from that, get practising and learning.
I was planning to pay for Mark's full course and get on with it. If anyone has any buying advice for watches/movements to start practising on it would be appreciated, I can obviously check out charity shops and eBay, but I wondered if it's worth picking up any of the Aliexpress automatic watches of questionable quality to strip down, clean and rebuild? Really don't know where to start with it.
Anyway, hope everyone is safe and well, take care.
Hi and welcome to the forum   As for tools you already have some cheaper versions so I would upgrade to either A*F brand screwdrivers or the french type, Tweezers of course Dumont . As the drivers and tweezers are the most used get the best you can afford at this time.  Watches to practise on  Usually advise to but Russian/Chinese, as they dont cost a mint and should you wreck one its no great financial loss, some of the Indian seikos are cheap but are sometimes cobbled movements and useful for practise work.  wish you all the best.
Hello and welcome.
Regarding practice movements, as watchweasol says, Russian and Chinese movements are good and low investment. Both tend to have conventional modern wristwatch movement design, so you learn to recognise the components and where they belong right from the start. Old pocket watch movements are good because of the size. Everything is a lot less fiddly, but many have significant differences to modern movements, which could be an obstacle to a steep learning curve. An exception to this is the Unitas / ETA 6497 or 6498 which has very conventional architecture and is of a size that can even fit in a larger wristwatch case (>42mm).
If you decide to do Mark's courses, and judging by the quality of his videos and free tutorials they are well worth it, you will need to get a Unitas / ETA 6497 or 6498 to work on. I think he actually uses a good-quality clone (Seagull ST36) which you can get for a good price on  AliExpress.
Other Chinese movements are available new or used for very cheap, but the quality varies wildly, and you will struggle to get exact fitting spares if you break something. I have found that generally the higher the quality of the movement, the easier the parts go back together. For example, the Swiss movements from the 50s and 60s were designed and manufactured to be serviceable, and are comparatively easy to work on. Ebay is a good place to shop for these, for a tenner or less. There are cheap mechanical watches from India available, but they apparently bulk-buy scrap movements  then canniblalise the worst ones for parts. The result is a running watch, but with dirty, worn, and "non-standard" components. Not good to work on!
Having said all that, in your particular circumstances, you might want to look at some alternatives to mechanical watch repair as a means of income. What about simple repairs and battery changes for quartz watches, or cosmetic work (case finishing, modding, individual dials). Just some ideas which might suit your existing skill-set better and give you a quicker way in.
Nice to see a local lad on this international forum (Penwortham born!).  New to this world too.  Just acquired (from fleabay) an old pocket watch movement and a couple of trench watches to experiment on.  Pocket watch is a non runner but only £12.99 so can't grumble with that.  Its about getting used to the parts and movements and cleaning.  What surprised me the most is the scale down sizes of a pocket watch movement to a wrist watch movement.  Probably an obvious thing but when you are working up close on them - it really stands out.
Hence i would advise on a set of magnifying goggles or equiv.  They come in handy with model making too.
The question of Loupes and binocular visors  has been discussed at length before on the forum, so I would suggest you use the search function at the top right of the home screen and have a look at the many varied opinions and make an educated choice on the data gleaned,       all the best
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
    • To get the full diameter, I'd have to take it out of the case, which I won't be able to do until the screwdrivers arrive.  I doubt that it's much use to you, but the raised rim on the case, encircling what you see of the movement, has an outer diamter of 28 mm and an inner diameter of 24.8 mm. The case outer diameter is 32 mm.
