Bayard carriage clock
chriseames168
Dear clock man,what I am saying is the air spring is not staying level when it moves back and forward it has got a lot of up and down movement too so it. Stops running as hits the side plate,looks like the pivot hole may be worn so maybe why it is getting the side unwanted movement, thank you again for your help,
This is not the type I thought of. It sound to me as if the balance staff might have broken, if there is too much play. Can you remove the two screws and remove the balance complete and look at the balance pivots, also the jewel holes, then could you post a photo, I can then advise you on what to do.
Hi,Yes it does wobble,when I put the clock face up lay it down the clock runs perfectly,like it did before,the balance wheel spring does still sit in ok the plates and does have some movement on each side of pivot hole so I think the pivot maybe worm of salf pin could be,but to be honest,not sure on how to repair,old hippy has ask me to take the unit out and take photos and he may advise me,have you got any idea as clock was also running perfect and just stopped one day and now get this wobble problem and doesn't keep running,only runs ok now when face up or down.,thank you again Chris.
Wobble of the wheel points out to either a broken pivot or warped wheel, that it stops reinforces the broken pivot assumption.
Hairspring coil is to be concentric( concentric circles), if coils are pushed to the side, it would need to be sorted out to bring all circles back to concentric, level and flat.
Once you take the balance complete out, both above said faults will be obvious and easy to see what we are talking about and pics help.
Hi A balance behaving as you have said would points to a broken staff pivot or jewel as the pivots when correctly fitted keeps  the balance verticle  with minimum of side shake and end shake. It is possible that the balance spring is deformed,   The only way to be sure is to remove the platform escapement and check.    BEFORE removing the escapement remove ALL power from the mainspring or you risk damaging the movement.       The attached PDFwill give you guidance.      cheers
LaBounty-ServicingAPlatform.pdf
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
