Hello, I just cleaned and oil my first pocket watch, good news
is now runs !
It has a small lever on rim that locks watch so it cannot be time
set after movement is in case. From pocketwatchdatabase ad
for watch says: "Patent self-locking setting device."
 Why make watch so it cannot be set to the time by crown
after movement in case ?? You do have to remove movement
from case, change lever and then you can change time if lever
was in " lock ". When lever in " unlock " the crown setting always
works.
Good morning and congrats on your success. Do you have photos of the watch and movement and the lever in question? The Lever you seem to be describing is typically for when the watch is outside the case so you can install the hands.
Hello, I wil add a photo to this reply. The lever is on front rim of movement I think about 3 oclock under dial plate. My
watch together working so I don't want to remove dial to get better picture. It took be hours to get hands on and
not hitting each other. I used my phone to take a picture every 5 seconds while I worked on watch, the picture I am
adding to this reply is one on them. Looking at picture about 1/2 inch to left of my thumb there is a silver lever on
rim held by one screw. The lever is connected to keyless yoke by linkage. When lever end (at edge of movement)
is down (level end can be moved about .25 inch on rim) the crown works for setting time. When lever is up the time
cannot be change using crown. Once movement is in case, the lever is held in place by case. Again, watch in case with lever
up time cannot be changed using crown. The advertisement for watch says " self-locking setting device ".
The lever pivots on single screw holding it in place.
So yes, as I remember it that lever is for placing the hands on the watch, and this has been discussed here before. Others here will know exactly what it is called, it just escapes me. At the moment, naturally.
This lever does no lock the hands, it only stops the crown from
moving them.
Does the movement actually need to be removed from the case in order to change the position on the lever or do you just need to unscrew the bezel holding the glass on the front of the case? Perhaps it would be useful to post a pcture of teh watch in its case with the case open.
The rim lever is under the dial. The case has screw on front, body
with stem and crown, and screw on back. To change lever you must
remove movement from body. The movement. only will come out
the front and the movement. two screws that hold movement to
body are on rear of movement. Therefore, the front and back must be
removed, then take movement out of body. The inside body rim holds
lever in " locked " or " unlocked " position. A picture with case front
removed only shows the watch dial, the lever is under dial.
I guest this it the mystery, why would you make a watch that can be
put in case and the time cannot be set without removing movement
completely from case ?
I think you may be able to remove front, remove back, turn 2
movement holding screws 1/2 turn, tilt movement up just enough
to move rim lever then but back together.
I would take more pictures, but I had such a time with watch hands
I am not going to remove dial again.
Edited by lakeradio6
add more
Go to YouTube, search video by " staying sane "
see his video Elgin 293 Disassembly
at 4.01 into video you can see levet at 6 o'clock at very bottom of
screen, it is in up, locked poistion. see linkage to keyless works.
Movement put in case this way time cannot be change by crown.
I believe this is the  patent document for the mechanism in question but it is not easy reading and I cannot work out what the function of the lever is from the patent. Perhaps it will help you or perhaps someone here can help decipher the patent.
I seem to remember reading somewhere that one of the requirements for some railway time keepers was that the hands could only be set by removing the bezel to access a lever in the rim of the movement so that they couldn't be inadvertently altered. I don't recall any need to remove the dial though.
Is it possible that this is a movement that has been recased and redialed using parts that don't accommodate this feature?
I originally suspected that this was a re-cased railroad movement but having seen the patent I don't think it is. It is a stem setting not a lever setting but for some reason unknown that lever is there. now I am as intrigued as the OP.
The movement you are referring to is called " levet set ".
Lever set watch had a pull out levet at about 1 o'clock.
To set time remove just front of case, with finger nail pull out
lever then with crown set time. After settling time push lever
back in and then replace front, now crown will only wind watch.
Search YouTube lever set watch and see many videos.
A very good video of my mystery level at 3 oclock is on
YouTube: staying sane video " 1917 Elgin 16s grade 293 assembly.
at between 15 and 16 minutes into video Mr Sane clearly
moves rim lever to what I call down position . This allows setting
time using crown. I have asked Mr Sane what lever is for.
Not sure in he will answer or knows answer, but I would bet
he knew to move lever down.
The movement in his video is same as mine.
Please see my reply to Marc below
My watch and rim lever is very clear on YouTube video
  • 3 years later...
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
