Old Half hunter pocket weatch
Welcome to the forum. We need to see photos but you're best searching eBay for prices.
Yes you should just be able to unscrew it. What's the movement number and what part did you buy from Cousins?
Well I've never seen a Citizen movement like that before. Can you confirm the size of the movement.
Hi all, I'm currently working on my second Omega Seamaster Cosmic 2000. While the movement is now 'under control', I have a new issue that I have not yet run in to so far. The stem of the Omega is a split stem, with male and female part. The female stem part (attached to the crown side) is broken. So I need to replace it, while of course keeping the original crown. When searching on google/Youtube I see a lot of examples where the threaded stem can be removed with the aid of a pin vice, just unscrew. But this stem looks different, see attached photo's. No thread and I can't tell if it's one part or multiple parts. I already have an Omega replacement female stem from Cousins, but that one is threaded and much thinner in diameter. Does anyone have experience with this? Can I just unscrew the stem from the crown, or does it work differently? Hope somebody can help!
We need photos, age and price probably just a rough estimate.
